Unread 08-28-2009, 10:15 AM   #1
crashman250
Curbless shower pan poured as part of a slab on grade
I am about to build a new house and was thinking of pouring and sloping the shower pan (curbless) as part of the main floor. I would use kerdi drain and membrane to waterproof the shower walls and floor. The entire house will be heated with radiant tubing in the floor. Can anyone find any problems with this design.
Thanks in advance James
James
crashman250 is offline   Reply With Quote
Unread 08-28-2009, 10:18 AM   #2
Rd Tile
Tile Man
Rd Tile's Avatar
If done correctly, nope.
I would waterproof the rest of the curbless floor outside the shower area with Ditra and kerdi band on the seams.
Richie.
Unread 08-28-2009, 10:20 AM   #3
Your concrete guys are going to leave you a recess in the floor for the shower, no? I would not trust them to slope the concrete for your setting surface, nor would I turn over the Kerdi drain to them for embedment.
Unread 08-28-2009, 10:21 AM   #4
Go to work, Richie!
Unread 08-28-2009, 10:23 AM   #5
Rd Tile
Tile Man
Rd Tile's Avatar
Wish I could.
Richie.
recessed slab for curbless shower on slab wakaru8 Tile Forum/Advice Board 4 05-26-2013 02:08 PM
Poured shower pan question tattoedtiledude Professionals' Hangout 12 11-19-2006 01:46 PM
Newbie: sunken shower on poured slab - Liner needed?? Mr. Fixit Tile Forum/Advice Board 3 12-13-2005 03:04 PM
pvc pan, slab on grade construction spur Tile Forum/Advice Board 3 08-15-2005 09:52 PM
Slab on Grade Shower Pan billrog Tile Forum/Advice Board 8 11-13-2002 08:01 PM
