Ok, so I did the leak test and noticed that there were a few small holes that need to be fixed.
(1) Can I just put a patch over each hole and seal it with thinset? I realize that Kerdi-fix would be the best product to use but I can't find any here. Perhaps another sealant would work?
(2) I have a bag of TEC Fullset plus thinset mortar leftover and will use that to lay the tile, OK to use? I don't want another fiasco like I had with the mastic.
(3) Also, I am going to eventually tile the cement floor. Will the TEC work ok by itself or do I need to add any additives to make sure the tile adheres good. I also have a bag of Customblend Standard Thinset Mortar (unmodified). Would that be better for the floor?
And just a word of advice to anyone tiling in a small bathroom. When you sit down on the floor, make sure your tape measurer is not directly under you.
I bruised my tailbone and there's not alot you can do to make it feel better.
Thanks for the help!
