Unread 04-16-2019, 10:38 AM   #1
JodyJetts99
thinset to tiles but Not over schluter membrane?
thanking everyone ahead of time. Hired a bathroom renovator to do complete schluter shower. I Insisted he use unmodified thinset over the drywall (under the orange schluter membrane) , which he reluctantly used. I also asked him to use the same unmodified thinset to set the tiles which he did not. He used a modified thinset. Needless to say my tiles have been curing for the last 2 weeks & also letting them dry for another 2 weeks before grouting. My question is, upon inspecting all the tiles I can very clearly see the orange schluter membrane between most of the tiles. He said he did NOT put thin set over the membrane ONLY to the backs of the tiles. Any suggestions. I am just sick over this. I called schluter, they explained that there needs to be thinset over both the membrane & the tiles for a good bond to occur they also advised I let them dry for a few more weeks. Do I scrap the whole shower and hire someone else to start it all over again. Any suggestions is very greatly appreciated? the reason I have had a new shower is I had poly b plumbing which leaked behind a wall and water sat downstairs for about 4-5 days and I lost so much stuff, I have just spent near $5,000 to have all my poly b replaced. Thanks again for any help at all about all the exposed schlauter membrane, I know grout will not waterproof those areas,
Jody
JodyJetts99 is offline   Reply With Quote
Unread 04-16-2019, 11:12 AM   #2
Welcome, Jody.
Tell us very specifically what thinset mortar was used to set the tiles, name brand, make and model, and what size tiles were installed.
The industry standard requirement for thinset mortar coverage in wet areas (your shower) is a minimum of 95 percent coverage on the back of each tile. It matters not at all how that is achieved, mortar on the wall, mortar on the tile backs, mortar on both, but seeing orange in the grout joints might be an indication that this was not achieved.
Unread 04-16-2019, 11:36 AM   #3
speed51133
the membrane itself is waterproof. the issue with not putting thinset on fully is that the tiles may fall off.
if you can see orange in every joint, I would not be surprised to find out the spot/blob method was used....
Unread 04-16-2019, 01:02 PM   #4
JodyJetts99
Visible orange membrane in joints
Thank you CX for your information. Tiles are 4X16. I asked him and he said he used “mapei modified tile thinset” , when I further questioned him today he said he did not use any thinset over the schluter membrane for purpose of setting the tile ( he did use it to apply the membrane to the drywall and overlap edges; curb, etc), he said he only used it to Butter the backs of the tiles, he said he pressed it onto the membrane, to sort of squish it in. He also did the same technique on the ceiling, but all the tiles look like they are stuck pretty good to both walls and ceilings, none have fallen off nor does it look like they have moved or slide down or anything. I do not see any of the orange membrane behind the tiny accent tiles, it seems pretty loaded with thinset. But really it is Almost every tile joint tops & sides I see orange. At this stage I can only hope he put enough thinset behind the membrane to attach it to the drywall. I have prayed that this shower will not have a major leak. This is a excellent website, I am not a handy kind of woman, I do not know construction stuff and not liking learning about it, but this site really has so much helpful information. Thank-you.
Jody
Unread 04-16-2019, 01:12 PM   #5
JodyJetts99
Mike, speed51133 thank you.
Thank you Mike for your reply. I’m not real clear on the spot/blob method but it sounds like where you plop some thinset on the wall and press the tile into sort of idea? I did ask him today and he told me that he did not apply thinset to set the tiles but that he buttered the backs of the tiles then pressed them onto the membrane to kind of make it squish. But I see orange membrane on almost every tile joint, both the sides and the tops & bottoms,. Crossing my fingers this won’t be a major leak down the road. The tiles used were 4X16 and he used modified mapei thinset. Tiles have cured for about 2 weeks so far Already and it will be at least another 2 weeks before I will have it all grouted. I will make sure he does silicone all the edges along where one wall meets another and the edges of the ceilings. Thanks again. This is an amazing site - so much very helpful suggestions, tips and advise.
Jody
Unread 04-16-2019, 01:18 PM   #6
ZZZK
Try tapping on various tiles in various places around each tile. Does it all sound solid and uniform or do you hear changes in the sound indicating areas that are hollow vs areas that have thinset. A hollow backed tile has a fairly distinct sound. This would immediately be a potential red flag that spot bonding or inadequate thinset coverage was applied.
John
ZZZK is offline   Reply With Quote
Unread 04-16-2019, 02:33 PM   #7
Lou_MA
If you’re checking for hollow tile, use the tip of a screwdriver or something else metal to tap around with.
Lou
Unread 04-16-2019, 06:38 PM   #8
Ask him again, Jody. MAPEI makes many modified thinset mortars and you want him to tell you exactly which one he used.
You have already waited much longer than you needed for tiles that size to be grouted.
The danger with the lack of proper mortar coverage on the back of your tiles is not so much a concern that they will fall off the wall, but in wet areas you can have other problems with installations having insufficient mortar between tiles and substrate.
Unread 04-16-2019, 06:48 PM   #9
I've back buttered tiles for 40+ years, I would stop worrying, sounds like he's doing fine.
Unread 04-16-2019, 07:05 PM   #10
HS345
Tile Contractor
HS345's Avatar
Originally Posted by Davy
I've back buttered tiles for 40+ years, I would stop worrying and let him do his job.
There is nothing wrong with back notching the tile (as I call it), I do it all the time. I think Jody is concerned that maybe the installer didn't key the mortar into the Kerdi membrane. While this is not ideal, I don't think it's the end of the world either.
The name's Greg
Unread 04-16-2019, 07:14 PM   #11
I agree with Greg. Not ideal, but not a do-over either.
Liquid Membrane/ Sheet Thinset Membrane Drain Connection Philosophy jasoncpe Professionals' Hangout 24 10-25-2015 10:44 PM
can i use Ardex 8 +9 to repair leaks in schluter membrane t049331 Tile Forum/Advice Board 4 03-19-2013 02:51 PM
Pulling up tile off Schluter membrane Brian_KS Tile Forum/Advice Board 29 10-24-2010 09:49 PM
Schluter Kerdi As Crack Isolation membrane Page Professionals' Hangout 7 05-11-2009 07:48 PM
orange membrane (schluter) nhut Tile Forum/Advice Board 11 07-29-2005 06:31 AM
