Unread 11-11-2011, 10:03 AM   #1
djjasper
How do you grout/seal/waterproof/moldproof/clean this??
Is there really any way to do this?
DJ
djjasper is offline   Reply With Quote
Unread 11-11-2011, 10:07 AM   #2
pwgsx
pwgsx's Avatar
o wow........ill be interested to see what the pro's say.
Phillip
pwgsx is offline   Reply With Quote
Unread 11-11-2011, 10:33 AM   #3
java
Hugging Trees Oct. 1st
java's Avatar
The easiest way to clean something like that is to sale the house and move.
Jason
java is offline   Reply With Quote
Unread 11-11-2011, 10:46 AM   #4
scut207
sweet mother of god... looks really nice but cleaning soap scum off that?!?!?
scut207 is offline   Reply With Quote
Unread 11-11-2011, 12:15 PM   #5
WendyHMN
Amateur Jack of All Trades
WendyHMN's Avatar
That is just wrong. I am planning a ledgestone wall behind the tub in my next bath project, but it's going to be a clawfoot tub with a curtain that goes all the way around. No way would I want soapy water hitting a wall like that. Actually, that's what I would recommend if you must actually use that shower. Hang a curtain or some plastic sheeting.
Wendy
Blue belt DIYer. Moderately proficient and occasionally useful.
See my finished master bath here.
WendyHMN is offline   Reply With Quote
Unread 11-14-2011, 10:10 AM   #6
pwgsx
pwgsx's Avatar
maybe Rhino Line it!! Guess you could always bring in your powerwasher and spray it clean.
Phillip
Unread 11-14-2011, 11:56 AM   #7
djjasper
Even with just an accent in he shower like this pic how do you do it- can the pros chime in on how you deal with this?
DJ
Unread 11-14-2011, 12:04 PM   #8
java
java's Avatar
We are Pro-Tilemen (and TileWomen) not cleaners.
Jason
Unread 11-14-2011, 05:49 PM   #9
djjasper
Right. I'll re-phrase the question;
How do you grout/seal/waterproof/moldproof this??
DJ
Unread 11-14-2011, 05:59 PM   #10
koihito
A person, like you.
koihito's Avatar
Grout: you don't.
Seal: any good spray on sealer.
Waterproof: your tile does not provide waterproofing, if the shower was properly constructed you are fine, if not, there is nothing you can do about it now other than tear stuff out and fix it.
Moldproof: you don't. You can't squeegee. Installing, and USING, a really good ventilation fan to get the moister out after you use the shower will help. If a surface applied membrane such as Ditra/Hydroban/Etc. was used it will help, but just like the waterproofing, you have what you have at this point.
Bottom line: that shower was ill conceived
Nate
www.mikoskiconstruction.com
koihito is offline   Reply With Quote
Unread 11-14-2011, 06:20 PM   #11
CanyonTile
Seal it with a Solvent based sealer and drench the heck out of it.
Those installs look good, people seem to fail to realize that not all designs are functional, wood planks on a bathroom floor are no more or less functional than those applications. I personaly think they look gorgeous, from a install point of view and a design point of view.
Cleaning ? A semi-soft nylon bristle brush and a quality stone cleaner.
Functional? Well maybe not in the same aspect as 4 1/4" lug D100. But looks a hell of alot better.
Gabe
We Got You Covered
www.canyontileandstone.com
CanyonTile is offline   Reply With Quote
Unread 11-14-2011, 06:27 PM   #12
420benz
As far as cleaning it. I would try to power was it.
Phil
420benz is offline   Reply With Quote
Unread 11-14-2011, 06:33 PM   #13
koihito
A person, like you.
koihito's Avatar
Phil, that has disaster written all over it! I would love to watch!
Nate
Unread 11-14-2011, 06:47 PM   #14
eurob
Not...Sure
DJ,
A pro will never recommend such materials to be used in these applications .
Steam cleaning may work .
Roberto
Unread 11-14-2011, 07:38 PM   #15
dhagin
This your place in SE PA?
dana
Best Way To Clean and Seal 15 year Old Grout PickleF16 Cleaning, Restoration and Sealing 7 08-11-2009 07:17 PM
Seal Grout Lines then Clean Haze from Slate? hurd Cleaning, Restoration and Sealing 1 03-01-2007 05:15 PM
Clean and seal same day? benjediver Cleaning, Restoration and Sealing 4 03-01-2007 11:35 AM
Blue seal (waterproof rubber membrane) over durock, overkill? newbieonhomes Tile Forum/Advice Board 4 07-27-2006 10:49 AM
Has anyone used BLUE SEAL WATERPROOF? fillmore Tile Forum/Advice Board 2 12-16-2005 02:22 PM
