Unread 10-16-2010, 06:07 PM   #31
Gukki
Thanks for clearing that up, I'm sorry Ed, I misunderstood.
No wonder my better half just shook his head, asking where I was getting my advice from, haha.
~~~~ellie~~~~
You can see my finished hall bathroom here
Gukki is offline   Reply With Quote
Unread 10-16-2010, 06:19 PM   #32
Ellie, I really think you should determine exactly what you have for subflooring. If, indeed, you have nothing but a half-inch layer over the joists, the advice on how best to install the second layer of 3/4" could be a good bit different.
Unread 10-16-2010, 09:54 PM   #33
Gukki
CX, it is 1/2" ply. Please tell me what would change?
~~~~ellie~~~~
Unread 10-17-2010, 07:34 AM   #34
1/2" by itself is far too flexible between the joists for tile (or appliances for that matter)
Unread 10-17-2010, 07:46 AM   #35
Gukki
Good Morning Paul,
I realize that. The question is, how the installation of 3/4" ply differs, due to only having 1/2" ply underneath.
~~~~ellie~~~~
Unread 10-17-2010, 08:39 AM   #36
Difference is not being able effectively to fasten second layer to the half-inch layer, Ellie. Can be done, of course, with proper pre-drilling and careful use of screws, but you'll likely be better of pretending it's not there and fastening your 3/4" ply to the joists as though it was the first layer. You'll get no real help from that thin first layer, anyway.
Unread 10-17-2010, 08:53 AM   #37
Gukki
I see. This will take a bit of preparation to avoid hitting all those nails holding down the half inch layer, pre-drilling and using long enough screws.
Thanks.
~~~~ellie~~~~
Unread 10-17-2010, 11:57 AM   #38
Shouldn't need to predrill if you use nice decking screws with torx or square drive heads.
Unread 10-17-2010, 06:06 PM   #39
Gukki
It's IN!
What a difference, it feels SOLID.
We fastened long screws into the joists and then used shorter ones to pull up the 1/4" ply as well.
CX, just as you said: it takes a bit of care to figure the proper pre-drill depth and then slowing the screwdriver to successfully pull up that 1/4" ply. But the screw lets you know with a nice squeaky sound when you've achieved it. Yeah!
Paul, this not being our day job, we didn't mind the pre-drilling. One of us drilled, the other fastened the screws, very companionable, we enjoyed it.
Thanks so much for being patient and answering all my dumb questions.
~~~~ellie~~~~
Unread 10-17-2010, 08:37 PM   #40
Ellie,
That's great to be able to work together like that.
There are no dumb questions, if this were easy, none of us would have a job.
Unread 10-18-2010, 09:40 PM   #41
Gukki
So the next project is to put the new fiberglass/acrylic tub into the alcove.
We are planning on using 1/2" CBU around the tub and extend a couple of inches into the rest of the room.
We'll use regular drywall everywhere else.
We will tile around the tub and continue to about halfway up around the rest of the room.
The alcove measures 60 3/4" in length. The tub including the tile flange measures only 60".
I have the following questions:
1. What can we do, so that the CBU will end up over the tile flange on both sides of the tub, not behind it?
2. If as a solution to the above question, we add wood to the studs to bring the CBU over the flange, then the drywall and CBU will not at all line up by about 3/4". How would we deal with that?
~~~~ellie~~~~
Unread 10-18-2010, 09:45 PM   #42
1. Shim out the studs (plywood strips my favorite) or sister additional studs to the correct plane (allows plumbing and flattening).
2. Shim out the rest of the wall or call that jog a feature and put a nice trim piece there. Features are good. Features are helpful. Features are our friends.
Unread 10-19-2010, 07:07 AM   #43
Gukki
CX, thanks for making me see that I have a new, good and helpful friend.
~~~~ellie~~~~
Unread 11-22-2010, 12:39 PM   #44
Gukki
joint compound on durock
Hi All,
Since my last post we've completed the plumbing for the tub/shower and insulated the whole room.
We had a contractor install the drywall and durock around the tub. He did a great job with the drywall finishing.
BUT, he also meshed/mudded the gaps between the durock with joint compound, which brings me to the following question:
Is this ok? Shouldn't he have used thinset for this along with specialty mesh?
A. Should we tile right over it?
B. Leave it and roll Redguard over it?
C. Sand it off and mesh and mud with thinset?
~~~~ellie~~~~
Unread 11-22-2010, 12:48 PM   #45
1- dopeslap the drywall guy
2- paint over it with Zinser (oil based that you can latex over in 1 hour) or Kilz
3- redguard and tile as usual
Hall of Hexagons gueuzeman Professionals' Hangout 20 05-19-2010 11:00 PM
Few more for the hall of shame Scottish Tile and Stone Professionals' Hangout 9 07-31-2009 09:16 PM
Hall bath Thisstinks Tile Forum/Advice Board 31 10-08-2008 08:42 PM
Deflection in hall Saint Toro Tile Forum/Advice Board 7 02-25-2008 01:03 PM
Hall layout kcp500 Tile Forum/Advice Board 4 09-26-2006 02:32 PM
