Unread 01-07-2021, 09:39 AM   #1
Creato
Gap Size Between Floor Tile and Drywall?
Is there an actual code requirement for the gap size between floor tile and drywall?
Joe
Creato is offline   Reply With Quote
Unread 01-07-2021, 09:42 AM   #2
Not that I'm aware of, Joe. Why do you ask?
Unread 01-07-2021, 10:13 AM   #3
mykcuz
No, there is no sheetrock inspection that I've ever heard of. By the time the inspector sees it, base trim is installed.
That said, 1/4-1/2" is good to avoid absorbing moisture into the wallboard, but you don't want an open hole for fire reasons. In case of a fire in wall, it would provide oxygen. Around me, inspectors will fail you for not sealing plumbing pipes under the sink for fire reasons.
Sent from my SM-G950U using Tapatalk
mykcuz is offline   Reply With Quote
Unread 01-07-2021, 10:36 AM   #4
Creato
CX- I ask because an employee of mine says there is and I've never heard of it. I typically leave 1/8" gap and never had an issue.
Joe
Unread 01-07-2021, 01:15 PM   #5
Hi Joe,
I think an eighth is adequate, but a quarter might be better. Base still covers it.
Unread 01-10-2021, 10:01 PM   #6
It depends somewhat on how big the tiled surface is and what the temperature variations are. The thermal expansion rates are a relative known, but the bigger the temperature variation is, the bigger the assembly will be and the gap requirement would grow. IOW, a smaller room can get by with a smaller gap than a huge one that might have a lot of direct sunlight or radiant heating, whether electric or hydronic. While ceramics are pretty stable, the coefficient of expansion is around 4.6x10 to the -6 per degree C. Say it's on a concrete slab, and the slab is cool at maybe 15C, and the sun is hitting the tile heating the surface to 35C, that's a 20-degree increase. If the room was 20' wide, 20'*20C-degrees*12"*4.6x10exp-6=.022" or a little more than 1/48" if I did the math right.
A plain ceramic tile will expand at a higher rate than a good porcelain.
What size trowel for multi size floor pattern? Nanker Tile Forum/Advice Board 12 03-23-2019 06:28 AM
shower floor tile size L. Tile Forum/Advice Board 3 08-17-2009 08:53 AM
Shower Floor Tile Size Johhny Tile Forum/Advice Board 3 12-17-2007 08:09 PM
? about best tile size for shower floor bassthecat Tile Forum/Advice Board 7 09-24-2003 08:20 AM
Tile size for shower floor ChazK Tile Forum/Advice Board 25 05-01-2002 04:54 PM
