Unread 04-26-2012, 09:27 PM   #1
DavidTu
Plumbing rough-in need your bestimates
We will eventually be installing a natural stone tile in the shower and on a wall backing a clawfoot tub. We need to set our rough-in plumbing valves and nipples at the right setback from the finish wall... which begs the question: how thick will the various layers end up being?
For the standalone shower we will have regular 1/2" sheetrock, Kerdi, thinset mortar, and 3/8" thick natural stone 16x16" tile, what are the thicknesses of the various layers from the studs to the finish surface?
For the tub wall (this is just a wall behind a clawfoot tub--not a tub surround--and no overhead shower), the tub filler is wall-mounted... so 1/2" Densshield, thinset mortar, 1/2" thick 16"x24" natural stone tile, what are the thicknesses of the various layers from the studs to the finish surface?
I'm sure there is some room for variation... just need your best guess for now.
Also, what is a good guess for a shower pan thickness? Right now we have 16" o.c. 2x10 floor joists, and 3/4" T&G sub-floor. (The shower is an odd L-shape so I don't think we can use the Schulter shower pan product and would have to use a traditional methodology.)
David
DavidTu is offline   Reply With Quote
Unread 04-27-2012, 12:03 AM   #2
Deckert
For plumbing purposes in the shower i'd figure 1/2" for your sheetrock, 1/8" for thinset and kerdi, another 3/16" for thinset, 3/8" for your stone. (This is being generous with the thinset/kerdi thickness, and stingy with the 3/16" thinset number if your walls aren't pretty flat)
Id guesstimate you'll have 1/4" of thinset under that stone on the tub wall (again, a little depends on how flat your walls are). So 1/2" + 1/4" + 1/2" from the studs out. And I'd give serious thought to some waterproofing here, even though its not a shower. And I'd waterproof the floor as well.
For the shower pan thickness, theres no set answer.
Brannigan
HeenanGC.com
Unread 04-27-2012, 06:11 AM   #3
What Brannigan said plus add to that any out-of-plumbness you'll have to build up for
Unread 04-27-2012, 07:30 AM   #4
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Natural Stone is Pretty Vague.....I have seen some Slate that you would get into trouble using that 1/2" + 1/8" or 5/8" for tile thickness ( or the above for studs out which would be adequate for Most polished stones and tumbled stones but there are exceptions.
Now, there is One other thing..Are you Dead set on a Natural stone in your shower???
They can be a maintenance Headache and with the options out there in Porcelain that look so close to natural the average joe wouldnt know the differance, I would consider saving your wife the extra work.
Seriously, the Stone will not add an appreciable amount of value over a Quality porcelain. It is more difficult to install, particullarly for a DIY'er, It is More expensive to Purchase, Install and Maintain.
Think about maybe using a Natural Stone as feature bar instead....it will add color and grain, leave a minimal headache area and will really POP while adding to the overall aesthetic look of the shower.
Up to you of course...just trying to save you money, time and Work without taking away from the end appearance and value gained!!
Unread 04-28-2012, 08:42 AM   #5
WendyHMN
Amateur Jack of All Trades
WendyHMN's Avatar
As a non-pro, what I did was make up a test board with all my various layers. That gave me an exact thickness to work from. I was very glad I did it as it showed me I would need to shim out my valve wall to get the right depth for my trim.
Wendy
Shower Plumbing Drain Rough In OverBuilt Tile Forum/Advice Board 9 11-29-2011 08:54 PM
How rough should it be? mikealdirch Tile Forum/Advice Board 5 11-04-2007 01:42 AM
Rough plumbing for toilet flange is too high BlueCanyon Tile Forum/Advice Board 23 09-14-2007 04:51 PM
How rough is too rough? (Pre-slope deck mud layer) BST Tile Forum/Advice Board 4 08-06-2007 08:47 PM
Rough Cost Sonso Professionals' Hangout 2 07-15-2007 08:39 PM
