Old 01-11-2019, 09:14 PM   #16
Lardog
Makes sense CX. Thanks for the explanation.
Yes Davy, that's what I'm referring to, the very outside edge of the tile wall, outside the trim piece where you see the Redguard.
I'll use thinset to set in place, using tape to hold up if needed. I'll mark off outside line with tape so I can easily clean up extra thinset.
Sounds like you are recommending grout, but that silicone would also work?
Thanks again all. I'm a complete noob at this, but am trying to do it right.
Cheers.
Larry
Larry
Lardog is offline   Reply With Quote
Old 01-12-2019, 07:05 AM   #17
Yep, that's a joint I would usually grout. If you place blue tape in a straight line about 1/16 from the edge of the trim, it'll pull away clean.
Old 01-12-2019, 11:44 AM   #18
Lardog
Good tip. Thanks.
Larry
Old 01-13-2019, 06:12 AM   #19
BelkTile
BelkTile's Avatar
Grout would be better
https://www.belktile.com
BelkTile is offline   Reply With Quote
How to attach pencil tile kevreh Tile Forum/Advice Board 8 11-08-2013 10:00 AM
pillowed edge/cushioned edge questions fresno Tile Forum/Advice Board 3 07-07-2012 09:31 PM
pencil tile - grout buckley8 Tile Forum/Advice Board 3 04-09-2011 02:52 PM
how to install ogee/pencil trim redmtnwolf Tile Forum/Advice Board 5 10-26-2007 05:58 PM
Edge chips in new install kitchengirl Tile Forum/Advice Board 12 02-15-2005 08:34 PM
