Unread 12-19-2010, 07:29 AM   #1
FGH
Toilet flange / Kerdi Drain advice
Hi Folks
I've got a dillema. My basement bathroom floor is tile over Ditra, over concrete with infloor radiant heat. Problem is the toilet flange is not installed and I tiled right up to the toilet drain pipe (rough-in sticks up about a foot).
I have been all over the internet on how to install the flange and most say it should have been installed before tiling so the flange will be flush with the finished floor.
Also, the flange I have is the type that gets cemented inside the waste pipe. However, there is no way I can drill into the concrete floor to secure it because I have no idea of where the infloor tubing runs.
I need some serious direction and advice on how to install the flange, and would appreciate advice on how installing the last piece of the Kerdi drain (part with the square drain cover) Does it get cemented in with PVC cement or just placed flush with surrounding tile with thinset?
Thanks in advance - really need some solid advice here.
Frank
Frank
FGH is offline   Reply With Quote
Unread 12-19-2010, 08:17 AM   #2
Frank, the toilet drain should sit down on the tile, not be flush with the tile.
Check this out about your Kerdi drain question. http://www.johnbridge.com/vbulletin/...ad.php?t=28637
Unread 12-19-2010, 08:56 AM   #3
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
Frank,
Like Dave said with the flange you are fine. If you don't want to drill a hole through tile and into slab, I guess you could use some glue and glue it down. I would be very supprised if drilling a few anchor bolts would penetrate into your plumbing though. You generally have a little bit of vertical drop in your plumbing before it makes the turn and heads to the sewer line.
Levi The Tile Guy
Unread 12-19-2010, 08:59 AM   #4
Welcome, Frank.
What Davy said.
You're apparently missing any of the serious plumbing sites. Everyone on those should know better.
You really think your hydronic heating tubes were run that close to the WC drain riser? That would be pretty unusual and rather incorrect, too. There should be plenty of room for you to install your toilet flange fasteners, which you'd really want with that plastic flange.
Unread 12-19-2010, 09:05 AM   #5
FGH
Levi:
I'm not too concerned about drilling & hitting the drain pipe. What I am concerned about is hitting the radiant tubeing in my basement slab. I don't know how deep the tubing is or how close it is to the toilet drain pipe. In finishing the basement, nothing was drilled into the concrete slab.
Frank
Frank
Unread 12-19-2010, 10:14 AM   #6
Turn up the heat and feel the floor near the toilet. It will be warm where the tubing is, and cold(er) where it is not. Such tubing isn't usually installed within the footprint of the toilet to avoid overheating the wax ring.
Unread 12-19-2010, 10:40 AM   #7
Get yerself one of those terlit flanges that;
1- slides right into the riser pipe, secured with normal PVC glue
2- has a stainless steel ring where the terlit bolts go.
3- move onto the rest of the floor
Install the ring after you set your tile. It will be perfectly flush at the height you need it to be.
like this
or this
Toilet Flange romanf Tile Forum/Advice Board 1 01-20-2010 10:12 AM
A Kerdi drain flange question TrimGuy Tile Forum/Advice Board 6 05-17-2009 08:43 AM
Kerdi membrane off-center over drain flange Grouthead Tile Forum/Advice Board 2 06-17-2007 04:36 AM
Toilet Flange JeffH Tile Forum/Advice Board 4 10-18-2005 09:01 PM
toilet flange? mpatheal Tile Forum/Advice Board 3 10-15-2001 02:37 PM
