Unread 05-16-2009, 03:18 PM   #1
TrimGuy
A Kerdi drain flange question
Gents,
I am about to start work on my sloping shower floor and will be using the Kerdi drain flange (PVC). The kit's installation DVD shows their demo guy setting the flange with no mention of using PVC primer and glue. In fact, it appears that he just sets the flange on the drain stub up w/out glue, using only the dry mix to stabilize it level.
I know you pros out there install a lot of this stuff...do you recommend using PVC glue or not?
Thanks very much! Love the forum - I always get the best advice here.
Steve
TrimGuy is offline   Reply With Quote
Unread 05-16-2009, 03:48 PM   #2
jgleason
jgleason's Avatar
Hi Steve,
Yes, you do want to glue the drain to the stub. Dry fit everything first to make sure you've got the right height.
Unread 05-16-2009, 04:34 PM   #3
TrimGuy
Cool - Actually that's what I thought and you confirmed it. We're all cut to height and ready to go. This was just a "to glue or not to glue" question.
Moving forward now....thanks!
Steve
Unread 05-16-2009, 06:29 PM   #4
Ken_and_Cindy
Steve,
I think the installation says that in new construction where you have access to under the shower, its better to install the drain then connect the plumbing afterward. I think that is what the demo movie is showing. If the drain is already there then you need to glue it.
Ken
Long time DIYer
Ken_and_Cindy is offline   Reply With Quote
Unread 05-16-2009, 06:59 PM   #5
jgleason
jgleason's Avatar
Good point Ken. When I did my shower a few years back I had access from below (basement). I mudded and set the KerdDrain before bothering to hookup the plumbing below.
Unread 05-16-2009, 07:13 PM   #6
You want to take a bit of your deck mud and mix in some more portland cement to make it stickier and easier to mush the drain into. You want it to stick, and a dry mix probably won't do that. It should be wet enough with enough cement in it to mush out of the holes in the flange when you push it down.
Unread 05-17-2009, 08:43 AM   #7
TrimGuy
Thanks to all for your insight. This is actually a slab substrate installation where I did all the rough plumbing a while back. I removed my old tub and adjacent single shower and relocated a new 2" drain in the middle. I had the stub sticking up and had cut everythng to length then.
I pretty sure the video was somewhat high-level. It certainly gives me plenty to go on. Glueing seemed common sense but I wanted to be sure. Thanks also for the tip about having enough cement to get the mix to key into the flange. I've worked out a procedure to backfill most of the opening before the flange goes on.
This has been a great site for me over the past year. Everyone has been really helpful. I'm sure I'llbe back once the Kerdi starts going up. There are a lot of angles. I guess some pictures will be in order.
Thanks again all!
Steve
Kerdi Drain question - HELP sling Tile Forum/Advice Board 5 01-14-2009 09:56 PM
Kerdi drain question Brian Shower guy Tile Forum/Advice Board 3 12-20-2007 06:04 PM
Kerdi membrane off-center over drain flange Grouthead Tile Forum/Advice Board 2 06-17-2007 04:36 AM
Another Kerdi drain question idarling Tile Forum/Advice Board 0 09-07-2006 01:46 PM
Kerdi drain question robwub Tile Forum/Advice Board 2 10-11-2003 05:39 PM
