Unread 01-23-2007, 05:59 PM   #1
Scuba_Dave
Extreme DIY Homeowner
Scuba_Dave's Avatar
7" Tile saw blade - need replacement
I bought a HD QEP 1/3 hp, 7" blade tile saw several years ago
I now need a new blade
The old blade lists 1.8 x 7
So 7", but what does the 1.8 stand for?
What should I be buying?
Scuba_Dave is offline   Reply With Quote
Unread 01-23-2007, 06:37 PM   #2
What will you primarily be cutting? Ceramic, porcelain, soft stones, harder stones, glass tiles?
Unread 01-23-2007, 06:42 PM   #3
Scuba_Dave
Scuba_Dave's Avatar
Up until now it has been all ceramic (I think)
Tiled my last bath, floor & walls, kitchen backsplash
My friend borrowed it to do his bath & kitchen
I'm not sure what his tile was
I'm thinking it will probably be ceramic, but possible we may buy porcelain
Future tiling projects:
Kitchen
Sunroom
Steam shower & bathroom
Unread 01-23-2007, 06:42 PM   #4
Mike2
I can't help you with the 1.8 part but here's the spec sheet on the current model of that saw. http://www.qep.com/msds_pds/QEP%20Pr...ta%20Sheet.pdf
It takes a standard 7" continuous rim diamond blade with a 5/8 arbor.
Dave, which blade to buy depends entirely upon the type of tile being cut. Here's a link to Construction Complete's website with many choices in the 7" size range. http://www.constructioncomplete.com/...ondBlades.html
I'll give you my own personal bias on blade choices for that little 7" saw: In the Ceramic/Marble category I'll recommend the Felker K-1000. It's a good general purpose blade and most likey a lot better than the stock blade that came with the saw. If you are primarly cutting porcelain then I'd go with the MK-225. And if Grantie, the Felker TM-5 would be my first choice for nice clean straight cuts. I actually have all of these blades so this recommendation has some actual experience behind it.
Unread 01-23-2007, 07:01 PM   #5
Scuba_Dave
Scuba_Dave's Avatar
Thank you
I may end up with a new saw before the next projects start
Depends upon the tile the wife picks out & how good the replacement blade works out with this saw
Unread 01-23-2007, 07:18 PM   #6
Mike2
Yep .
And good luck with your upcoming project.
Unread 01-23-2007, 08:40 PM   #7
Scuba_Dave
Scuba_Dave's Avatar
Well the saw blades at HD start at $22 (none in stock)
then $35
then $50 - which is about what I paid for the saw
So, are these prices "normal" or high because they don't sell that many
I can buy (3) online for $20 with shipping - "Workforce"
I literally have 6 tiles left to cut
I figure these would get me thru the 6 tiles
ooops that link was for dry blades, here is the wet blades
7/8" arbor, I need 5/8"
http://cgi.ebay.com/Qty-3-7-Diamond-...QQcmdZViewItem
Unread 01-24-2007, 12:43 AM   #8
sandbagger
sandbagger's Avatar
Dave - I picked up a 7" Hot Dog at Amazon recently for about 40 bucks. Free shipping and no tax. The pros seem to have mixed opinions about the Hot Dogs, but I'm pretty happy with it. I think the knock is it's a little thin and that's a problem on some of the table saws where the mount thingie for the blade cover that sticks up just past the trailing edge of the blade might be thicker than the Hot Dog. In that case the cut might not be wide enough to pass by.
I put mine on one of those Husky grinder saws and it works like a champ.
-art-
__________________________
Patrick Henry
Unread 01-24-2007, 08:59 AM   #9
Scuba_Dave
Scuba_Dave's Avatar
For now I'm going to do the 3 blades for $20
Then look for a good saw to replace this saw
It's a decent little saw, but with the upcoming projects it makes sense to buy a good saw
Unread 01-24-2007, 09:34 AM   #10
Scuba_Dave
Scuba_Dave's Avatar
Well, after a further search here looks like I do not want the want the segmented blade as it is more prone to chip
Unread 01-24-2007, 11:41 AM   #11
Scuba_Dave
Scuba_Dave's Avatar
Well, I bought a 7" saw blade at Lowes
and it's actually 7 1/4" & will not fit
So back to the stores & check HD
