Unread 03-30-2018, 11:31 AM   #1
MarvalSam
Kerdi drain flange covered by pan?!?!
Hi guys, we're finally around to getting the pan poured and so far on attempt #2. Had my plumber pour this one, but his guy didn't follow the instructions and instead poured over the lip of the flange so it looks like the pic below (not like how it's supposed to be) and it created a "hump." Is this a jackhammer it all out and get a new drain/flange or can I compensate with a new layer to create the proper slope (doubtful, but I'm beyond myself angry).
Samantha
MarvalSam is offline   Reply With Quote
Unread 03-30-2018, 11:32 AM   #2
MarvalSam
Flange... not flame. Damn autocorrect..
Samantha
Unread 03-30-2018, 12:23 PM   #3
Lou_MA
Unfortunately, it’s a jackhammer out and replace drain and pan. The fleece on the drain will be wrecked trying to get it clean.
Also - what did plumber use for the pan? Concrete? It should be deck mud, a very weak mix that’s mostly sand, with a bit of cement.
Lou
Lou_MA is online now   Reply With Quote
Unread 03-30-2018, 12:45 PM   #4
MarvalSam
Lou, thanks for the response. I got it down to the fleece without any damage (amazingly)!
Samantha
Unread 03-30-2018, 01:27 PM   #5
ZZZK
Samantha what's up with your shower walls? I see a big gap between the pan and the walls. Do you have a wider picture?
John
ZZZK is offline   Reply With Quote
Unread 03-30-2018, 01:39 PM   #6
It would be best at this point if you use a straight edge and a level and check all the way around the floor, making sure you have a smooth, gradual slope from the walls to the drain, with no dips or humps, and a bare minimum of fall of 1/4" per foot.
Unread 03-30-2018, 01:46 PM   #7
MarvalSam
John, I noticed that as well. It looks worse in the pic because it seemed to get darker up against the wall. He's heading back over to look at it this afternoon.
Kevin, yeah, its definitely bumpy. I got some of it sloped right with a masonry sander, but it needs some addl work get the slope right since a lot of it is level or dipping on the edges...ugh
Samantha
Is this Kerdi drain flange going to bond correctly? bernz Tile Forum/Advice Board 17 08-13-2014 07:10 PM
retro kerdi drain into flange drain? figaro Professionals' Hangout 11 12-20-2012 04:02 PM
Toilet flange / Kerdi Drain advice FGH Tile Forum/Advice Board 6 12-19-2010 10:40 AM
A Kerdi drain flange question TrimGuy Tile Forum/Advice Board 6 05-17-2009 08:43 AM
Kerdi membrane off-center over drain flange Grouthead Tile Forum/Advice Board 2 06-17-2007 04:36 AM
