Unread 10-23-2020, 02:01 PM   #1
danmendez29
Help with underlayment
Hey guys im looking to get some advice on what i should do for the underlayment for a tile floor in my kitchen. I know i need to have a cement type board down before the tille, but manufacture says to have 5/8 minimum plywood subfloor before installation. the house i have was built in 1850 and subfloors throughout house are 5/4 then have a wood "plank" floor on top of the 5/4. my question is am i good to use what's already there as the subfloor or do i absolutely have to add another layer of 5/8 or 3/4. obviously this isnt a way i want to go. i have attached a picture of the kitchen floor.
danmendez29 is offline   Reply With Quote
Unread 10-23-2020, 02:21 PM   #2
You need at least 1/2" of ply. TO keep the buildup lower, you could go with a membrane versus a cbu product. FWIW, planks just move too much, and you need something more substantial than cbu on top of them for stability.
Have you checked your floor joists for strength? Are the planks T&G?
Unread 10-23-2020, 02:32 PM   #3
Welcome, Dan.
You'll need to remove that top layer of flooring, which in your photo appears to be what would usually be called strip wood flooring rather than "planks" as you suggest.
Then you would need a minimum of nominal 1/2" plywood over the 5/4 board subfloor before your tile substrate.
The minimum nominal 5/8ths" plywood requirement you see for most CBU manufacturers presumes that material as a single layer subfloor, which I would not recommend tiling over on a bet.
Unread 10-23-2020, 03:15 PM   #4
danmendez29
i was afraid that was going to be the answer. Not sure what i want to do now. forgot to mention this is a rental property and afraid of putting too much money into it.
Unread 10-23-2020, 05:31 PM   #5
A tile floor doesn't care who lives in the house, Dan, it should be installed the same way regardless the intended user. Really it should.
Unread 10-23-2020, 09:26 PM   #6
risotttto
CX has a point, If you own the building, think of any future costs to repair a crappy underlayment when you have to rip everything up again 5 years down the line because you didn't put the money and effort in up front.
-S
risotttto is offline   Reply With Quote
5mm Underlayment wiz02 Tile Forum/Advice Board 13 03-02-2016 12:27 AM
Do I need underlayment? Stonebunny Tile Forum/Advice Board 1 01-06-2007 05:22 PM
Underlayment Gary K Tile Forum/Advice Board 8 06-30-2004 02:28 PM
underlayment rreddy Tile Forum/Advice Board 7 05-25-2004 05:19 PM
Do I need more underlayment? regalan47 Tile Forum/Advice Board 20 11-26-2003 03:55 PM
