Unread 10-23-2020, 07:51 AM   #1
David-DIYer
Knee wall not level - What would you do?
Hi folks,
I searched the forums, and though I found some great information, I couldn't find the answer to my very specific question.
I have above average DIY skills, but far from being professional. I rebuilt my entire shower and went with the Kerdi system, with 2 coats of Ardex 8+9 (72 hour flood test PASSED!). I originally purchased an e-book about 10 years ago when the old shower first started leaking.
As I don't have much experience with this large of a project, and all the various skills needed, I made some mistakes - The biggest mistake is not correcting the knee wall (short wall between shower and tub) for level, see photo below:
I just ordered the glass for my shower, and after getting final measurements, I realized how out of level this wall is (The outside walls are perfect, and I did add blocking), and the guy at the glass shop gave me plenty of warnings, that even though I went with his recommendation of using U-channel in this location (instead of clips) that I'm going to likely have serious problems installing the glass myself.
This small knee wall was a headache for me trying to get the tiles perfect, and for sure I would've rebuilt it if I had to do it over.
Yes, it's slightly over 1/4 inch between those 2 "X" measurements!
Question: If this was your own project, what would you do? Is 1/4" not that big of a deal since U-channel gives some room for play? Or would you pop off enough tiles on the knee wall and deck tub, and correct this issue?
Thanks in advance,
David
David
David-DIYer is offline   Reply With Quote
Unread 10-23-2020, 07:56 AM   #2
Welcome, David.
If I understand your drawing, it's not the level top of that wall that's the problem, but the fact that it's not plumb. Would that be correct?
Unread 10-23-2020, 08:06 AM   #3
David-DIYer
Hi CX! Thanks for the prompt reply. I realized I should've referenced the diagram below when I stated the wall is not level.
You are correct, the vertical edge of the knee wall is not plumb.
All other vertical surfaces are plumb, and the tub deck (top of knee wall) is level.
Thank you!
David
Unread 10-23-2020, 08:15 AM   #4
In that case I'd have the fixed glass cut to fit the existing and remind myself to do better at framing the walls in future.
Unread 10-23-2020, 08:32 AM   #5
David-DIYer
Wow, I didn't even think to request the glass be cut to account for my poor workmanship. But a great idea, and I wouldn't need to remove and redo that section of tiles/wall!
David
Unread 10-23-2020, 10:21 AM   #6
john619
absolutely have the glass templated to accommodate the out of plumb section. Hopefully your tile size and pattern do not accentuate it, but its only off 5/16".
But I would not attempt the glass install DIY and leave that to a glazing pro.
john
Unread 10-23-2020, 11:12 AM   #7
David-DIYer
Thanks for all the input. I originally intended to do the whole project (full bathroom) myself. I think I'm in over my head with the glass install, I'll pay the pros to do it.
Thanks again guys, much appreciated!
David
David
Half Wall / Knee Wall for shower SethAMG Tile Forum/Advice Board 10 04-29-2014 01:33 PM
knee wall on hardibacker? doenute Tile Forum/Advice Board 2 01-03-2013 07:29 PM
Best material to level a knee wall 1/2 inch? Marilee Ruggles Tile Forum/Advice Board 2 05-21-2009 04:58 PM
3-wall tub w/knee wall - how to tile and top it? biondanonima Tile Forum/Advice Board 6 08-11-2007 04:54 PM
Knee Wall Heights YuHu Tile Forum/Advice Board 9 08-10-2006 07:34 PM
