Unread 10-17-2020, 10:03 AM   #1
Scolemann
Cleaning Mapei Flexcolor CQ Grout
Hi All, I installed Mapei Flexcolor 3 years ago in my shower. Rdgardless of regilar cleaning it has discolored in places. Any advice on cleaning this grout? I’ve tried a variety of cleaners with no succes.
Cole
Scolemann is offline   Reply With Quote
Unread 10-17-2020, 10:54 AM   #2
Hi, Cole.
Discolored, as in a color change to the actual grout? Or there’s some surface contaminant that you can get off?
Can we ask what you’ve tried for cleaning so far? And are there any unusual hair or soap products being used in the shower?
Unread 10-18-2020, 10:22 AM   #3
Scolemann
Hi,
Thanks for the reply! I’ve tried Comet, Scrubbing bubbles, Vinegar, and a couple other household cleaners. I usually let them sit for a bit and then scrub.
I imagine it probably is surface contamination, but can’t be sure. The grout is lighter around the drain, about a 2 ft diameter.
I’m the primary user and it’s mostly Dial and Head & Shoulders
Cole
Unread 10-19-2020, 12:48 AM   #4
Have you tried a more specific product like one of the many ‘heavy duty tile & grout cleaners’’? They are higher in pH than many cleaners that will assist in breaking down things like soap scum. You can find them sold anywhere that sells tile. Typically, it comes in concentrated form that needs to be diluted. Follow the directions which almost always include flooding the surface to clean and allowing to dwell for 5-7 minutes, then agitate with a fine nylon bristle brush. Then wet vac the dirty mess off to prevent the dirt from being re-deposited elsewhere. Then rinse with water to neutralize the pH and vac that away.
Unread 10-19-2020, 07:32 AM   #5
Jason@mapei
Jason Cantin Mapei Technical rep
Jason@mapei's Avatar
Cleaning Mapei flexcolor
for regular everyday use we recommend a PH neutral Cleaner. Like
https://cdnmedia.mapei.com/docs/libr...rsn=bbc722e8_0
The other concern may be that the Grout is getting saturated from underneath.
Here is another document you may find useful.
https://cdnmedia.mapei.com/docs/libr...rsn=a5376697_4
Jason
Jason@mapei is offline   Reply With Quote
Unread 10-19-2020, 07:59 PM   #6
Scolemann
Thanks for the recommendations guys, much appreciated!
Cole
Mapei Flexcolor CQ nelsonkoehn Professionals' Hangout 425 11-20-2020 06:39 PM
Mapei Flexcolor 3D MudMaker Professionals' Hangout 46 08-01-2018 07:30 AM
Pro Fusion or Mapei Flexcolor CQ Smitty1328 Tile Forum/Advice Board 23 01-07-2017 11:17 PM
Mapei flexcolor cq vs customs prism vs grout additive? Shady at Best Tile Forum/Advice Board 2 03-18-2016 10:27 AM
