Unread 10-16-2020, 07:35 AM   #1
gombi
Kerabond unmodified vs modified
I’m sure this was asked before, but I could not find a clear answer.
I have a wall, part painted gypsum board, part cement board. I will be installing 8x8 and 12x24 tiles. I want to use unmodified Kerabond thinset as I have that already. Do I have to use modified thinset, or am I good with what I have?
gombi is offline   Reply With Quote
Unread 10-16-2020, 08:07 AM   #2
MesaTileworks
What kind of tile are you installing? Is this a bathroom/shower/wet area, and if so, how are you planning to waterproof? More info about your project might help the community here advise...
Sent from my Pixel 2 XL using Tapatalk
MesaTileworks is offline   Reply With Quote
Unread 10-16-2020, 08:12 AM   #3
gombi
Bathroom but not a wet area. The wet area is already done with kerdi and unmodified thinset. Ceramic tile 8x8 and 12x24.
Unread 10-16-2020, 08:57 AM   #4
If the cement board doesn't have a rolled on water proof coating the unmodified mortar should be just fine. Might double check your tile though, some manufacturers want their tile adhered with modified.
Also check the age of the mortar you currently have, and if the bag has been already opened for a while.
Unread 10-16-2020, 09:43 AM   #5
Mike, all manufacturers of CBUs recommend modified (ANSI A118.4) thinset mortars for use on their products. I'd also recommend a modified mortar for use over the painted drywall after you have abraded the surface.
Will the Kerabond mixed with water stick the tiles? Probably, but I'd still recommend you spend the 15 bucks for a bag of modified.
Ever mix modified and unmodified? MDahn Tile Forum/Advice Board 7 04-23-2010 12:50 PM
modified vs unmodified Bella Vista Tile Forum/Advice Board 1 06-23-2008 11:25 AM
modified or unmodified? timothy Tile Forum/Advice Board 24 02-08-2008 09:48 AM
unmodified vs modified MannyG Tile Forum/Advice Board 14 01-11-2005 12:59 PM
?? Modified vs. Unmodified ?? DrewZ Tile Forum/Advice Board 4 06-26-2004 04:57 PM
