Unread 09-16-2019, 05:06 PM   #1
deejam
Kitchen Backsplash, 4x12 porcelain, layout decision
Hi Everyone, Thanks so much for all the advice these forums have provided in the past. I'm a tile novice as i have only completed 2 personal tile jobs (a kitchen and bathroom floor which i and wife were very happy with).
This backsplash will be the third job, which is the same kitchen where i completed the floor. This past weekend i have been trying to make some final layout decisions and have a dillema i would really appreciate some feedback on.
Materials:
tiles = 4x12 rectified - (Suave Bianco Polished 60-508)
www anatoliatile com /collections/mayfair
spacers = 1/16" blue horseshoe
thinset = mapei ultraflex 2
grout = mapei ultracolor plus FA (frost)
Essentially, i think my question is this:
What is more important regarding a kitchen backsplash layout? Grout line symmetry around kitchen sink/faucet/window and stove/hood area, or skinny tiles at the edge?
Right now i have 2 courses of the tiles layout on the protected countertops. I can easily shift the layout one direction or the other to avoid any cuts less than 3inches at all edges, but then the grout lines will not line up with sink/faucet etc.
When I line up the grout lines so there is symmetry with the kitchen window/sink/faucet i end up with a few skinny tiles at the edges. The skinniest tile would be about an inch thick.
I'll try to get some pics uploaded when im allowed to better show what i'm working with.
Thanks much,
Deejam
Deejam
deejam is offline   Reply With Quote
Unread 09-16-2019, 09:08 PM   #2
Welcome to the forum, Deejam!
One of the more important rules of design is: Do what looks good. If you rig up a mock up of each on the wall, it might speak to you enough to make the choice.
Otherwise get some pictures on here so we can impress you with our fabulous design prowess.
Unread 09-16-2019, 11:36 PM   #3
deejam
Thanks much, Tool Guy!
Here is an overview of the back splash wall in question. Fortunately, no corners on this south wall.
I plan to run the tile flush to the ends of the cabinets finished off with trimtec aluminum silver edging.
Here are some measurements:
160 1/4" - full horizontal length to cabinet ends. includes tile and edging
18" to cabinet overhangs
19" to cabinet bottoms
25" to hood bottom
8 3.8" to bottom of window trim
On the full wall pic, the yellow circles indicate were the narrow cuts would be. Far left edge and then both sides of the window. The skinny cuts in these 3 locations would be an close to an inch or just over.
Side note: the trim is not on the window yet, though i did put the left and right pieces in place for the sink pic.The trim will be reinstalled and windows will be painted white before tiling.
Deejam
Unread 09-16-2019, 11:55 PM   #4
With a running bond pattern, it's fairly likely to end up with some smaller pieces. It's just the nature of the pattern. But the grout lines aren't going to stand out in this case. The tile is what everyone will notice. So, if you like this pattern, then go ahead.
Unread 09-16-2019, 11:59 PM   #5
deejam
Here are a few closer shots of the edges.
Probably should have said this earlier, but I am planning the half offset brick pattern.
Just not sure about those narrow cuts at the far left edge givin that it opens up to another room. I assume an inch is considered skinny, or a sliver. From searching it seems most recommendations are to avoid anything less than half a tile length when possible and to keep symmetry of the focal areas (which seems to be everywhere!)
Thanks for any feedback.
Deejam
Unread 09-17-2019, 12:20 AM   #6
deejam
Thanks again for the feedback, Tool guy.
hmm, I guess i we are not to hung up on the running bond pattern. Maybe its worth seeing how a 25% - 35% offset might look.
Are you thinking that the since the grout color is close to the tile the grout lines will not stand out much, therefore it might be okay to sacrifice some symmetry for some larger end cuts?
Deejam
Unread 09-17-2019, 05:17 AM   #7
With a running bond pattern, you are almost always going to have less than half a tile on every other course. That’s why I said it’s the nature of the pattern. It’s almost impossible to avoid small pieces.
Unread 09-17-2019, 06:19 AM   #8
Elkski
Elkski's Avatar
the kitchen command center is the sink... make that look pleasing and take the rest as it comes.
Teddy
Kitchen Backsplash Price what do you think about my decision. Golden Tile Professionals' Hangout 20 06-24-2012 08:11 PM
How to layout tile in a kitchen backsplash Pirate Tile Forum/Advice Board 27 05-29-2010 02:24 PM
Kitchen Backsplash- Layout Question slick_spe3 Tile Forum/Advice Board 2 02-12-2008 01:16 PM
Kitchen Backsplash Layout John24689 Tile Forum/Advice Board 1 04-19-2006 03:30 PM
Kitchen Backsplash layout questions jdburger Tile Forum/Advice Board 18 12-31-2005 12:07 PM
