Unread 09-09-2019, 03:46 PM   #1
ave8er
Respect for the pros
Looking for ideas. I replaced a tub with a shower. I chose some larger tile and I placed a niche so it would line up on grout lines. I never thought about the window. If I use a travertine window sill would it make the slivers look less obvious? The “slivers” will measure about 7/8” also I leveled the tiles with a laser turns out the window is almost 1/4” higher on the right than the left. I am thinking I could possibly shim a travertine sill slightly to lessen the impact of that?
Paul
ave8er is offline   Reply With Quote
Unread 09-09-2019, 05:12 PM   #2
SpaceCadet
I'm not a pro and I don't have a good answer to your question but that looks like aquadefense and a big window. If you're taking your time doing this, you might want to cover the window. AquaD is UV sensitive and will start cracking after about a week if exposed to direct sunlight.
Paul
SpaceCadet is offline   Reply With Quote
Unread 09-09-2019, 05:18 PM   #3
ave8er
I had no idea. Thanks for the heads up. It is low e glass but I will still cover it.
Paul
Unread 09-09-2019, 05:31 PM   #4
speed51133
Is the aqua painted on drywall?
Unread 09-09-2019, 06:11 PM   #5
ave8er
No the walls and all around the window is 1/2 hardie backer
Paul
Unread 09-09-2019, 07:24 PM   #6
You could get a fabricator to make you a 2cm (about 3/4) piece with a 2cm dropped edge for the sill. That would hide nearly all of it. The only problem is 3/4 may be too thick for the window sill. The edge of the sill would be 1 1/2.
Unread 09-10-2019, 04:53 AM   #7
Elkski
Elkski's Avatar
Just tell people you did your level best but the window installer sucked
Teddy
Unread 09-10-2019, 07:00 AM   #8
Is the window itself out of level or just the opening? Or both?
Unread 09-10-2019, 07:50 AM   #9
ave8er
the window is out slightly less but still out of level
Paul
Unread 09-10-2019, 09:53 AM   #10
I'd do what Davy suggests. Ideally, you'd have as big of a piece as possible there to hide the problem, but that ship has sailed.
I had a similar problem at a buddy's house last year. Thank goodness I was only doing the mud and waterproofing for him, and he did the tile.
Unread 09-10-2019, 04:50 PM   #11
It's not very often I see a level window sill.
Unread 09-11-2019, 06:53 AM   #12
ave8er
Davy, your photo gallery is fantastic. I like the fabricate the window sill idea. 3/4 may work
Paul
Unread 09-11-2019, 07:38 AM   #13
speed51133
Or a square window sill either.
I did all the shades set within the returns in all my windows. The variation drove me nuts. I wanted all the shades within a 1/16in of the sides. Forget it. I think I was able to get that on ONE window in a house of like 30.
Unread 09-11-2019, 02:07 PM   #14
ave8er
Here is a great pic... tiny level sitting on the sill
Paul
Unread 09-12-2019, 06:34 AM   #15
SpaceCadet
Looks like the fasteners are pretty sparse. Their instructions specify 8" spacing here (pg 4): https://www.jameshardiepros.com/geta...ish-HB1710.pdf
Paul
New profound respect for Tile Installers Gordon Kaske Tile Forum/Advice Board 9 03-05-2012 11:00 PM
I have so much respect for all of you skilled tilers Novice_Tiler Tile Forum/Advice Board 3 02-25-2008 09:40 PM
Here is what happens when you dont respect control lines Scottish Tile and Stone Professionals' Hangout 16 09-12-2006 11:29 AM
Respect for the Pros dexter Tile Forum/Advice Board 5 05-15-2005 10:33 PM
respect your tile helper tilesnake The Mud Box 47 03-04-2004 01:12 AM
