Unread 08-28-2019, 01:30 PM   #1
Humphreyp
Tile over finished oak floor.
I have a nice polyurethane oak floor. Pretty solid. Good shape no deflection.
Can i run 1/4" hardi. 1 5/8" screws and tile away? No doors or radiators to worrie about.
Patrick
Humphreyp is offline   Reply With Quote
Unread 08-28-2019, 02:30 PM   #2
john619
have you checked the framing for deflection?
john
Unread 08-28-2019, 02:39 PM   #3
Humphreyp
Yes. Its fine. The question would be about hardi an tile over oak
Patrick
Unread 08-28-2019, 02:42 PM   #4
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
For clarity, do you mean to say you have an oak tongue and groove conventional strip floor with polyurethane as a finish?
Assuming yes above, no approved method will specify the hardwood floor as a suitable substrate for tile assembly...Hardi Backer or not. You need to get to subfloor beneath.
I would check joist structure before anything, though.
Peter
Unread 08-28-2019, 03:06 PM   #5
speed51133
When you say the joist structure is fine, what do you mean?
Unread 08-28-2019, 03:06 PM   #6
Humphreyp
Yes. And thats what i thought peter
Patrick
Unread 08-28-2019, 03:07 PM   #7
Humphreyp
Mike....by yes i mean the floor frame work is acceptable deflection wise.
Patrick
Unread 08-28-2019, 05:10 PM   #8
Patrick, it's your floor and your tile and you can install it any way you like, but no manufacturer of CBUs, nor the ceramic tile industry, will approve an installation over sawn board flooring.
Unread 08-28-2019, 05:54 PM   #9
Humphreyp
Agreed.
Patrick
Unread 08-29-2019, 03:01 PM   #10
Elkski
Elkski's Avatar
refinish those hardwoods?
Teddy
Unread 08-29-2019, 03:19 PM   #11
The issue is two-fold...ensuring planks are well attached so they can't move is tough and impossible if they're not T&G without way too much work, and more important, solid lumber moves way too much with seasonal humidity changes to allow tile to survive long-term. You need something more stable, which is typically plywood, then, you can add your choice of thinset compatible material that could be cbu, or a special membrane designed for this.
Under floor radiant heat finished with tile Davethebuilder Tile Forum/Advice Board 11 12-26-2010 12:47 PM
Kitchen Floor - Subfloor to finished tile Shaver Tile Forum/Advice Board 6 01-27-2010 12:29 PM
Just finished my second tile floor Would like to know what to do better next time dpbj6 Tile Forum/Advice Board 8 05-04-2007 10:45 PM
Just finished first tile floor what do you boys thinks dpbj6 Tile Forum/Advice Board 10 04-10-2007 06:49 PM
Finished height of ceramic tile floor Treetop Tile Forum/Advice Board 2 08-28-2006 01:53 PM
