Unread 10-20-2019, 04:39 PM   #1
godblsmnymkr
Possible to unseal marble tile?
hey guys. I bought marble mosaic tile and installed it in my bathroom. i did a test spray on some tile not on the wall with this sealer and it turned out fine. i then put it on all my tile on the wall.
https://www.homedepot.ca/product/cus...ler/1000410108
after i did 2 coates and wiped it off it left the tile looking like it does when its wet. basically takes all the color out of the tile and the colored pieces to the tile look really bad.
this is the tile i used. https://www.homedepot.com/p/Jeffrey-...9615/203485321
is there anyway to remove that product from my tile to return it to its natural state? ty!
aaron
godblsmnymkr is offline   Reply With Quote
Unread 10-20-2019, 05:24 PM   #2
The sealer is doing it's job. I've never known a way of reversing the enhancing but you might call Customs to see what they have to say. Or maybe someone else knows and will chime in.
Unread 10-20-2019, 06:29 PM   #3
godblsmnymkr
https://www.tileshop.com/products/su...1-quart-220029 wonder if this would work
aaron
Unread 10-21-2019, 08:24 AM   #4
MAPEI - Technical Service
Company Representative
Aaron, I can’t speak for other sealer manufacturers, but I can tell you that the enhancing/enriching effect is considered permanent with our products. You could try a good sealer and coating stripper and see what it does, but I’m not incredibly hopeful in this situation unfortunately.
Holden
http://www.mapei.com/US-EN/
Unread 10-21-2019, 12:31 PM   #5
godblsmnymkr
https://www.custombuildingproducts.c...er-sealer.aspx
installation guide says cannot be reversed. i guess i'll apply another coat to blen in all the blotchiness on the colored tile. thanks guys
aaron
Unread 11-30-2019, 11:55 PM   #6
katilicous
Aaron,
Is this tile flat or is it like a ledger stone? If it's flat and not polished you can hone or grind or sand the surface to remove the color enhancing look . It's an impregnating sealer but marble is denser stone and usually it only impregnates into the stone a little . If you are getting blotchy results it could be that your walls weren't wiped down and a grout and or mortar haze is on the surface of the stone.
The guide always says enhancers cannot be removed but if you call Customs they might have a trick besides honing that will take away the enhancing look. Don't add more if you don't like the look.
Kati
katilicous is offline   Reply With Quote
Unread 12-02-2019, 09:41 AM   #7
I agree with Holden and your installation guide. It seems to be a water-base sealer, and I know for a fact it can't be reversed. Sorry.
Darkening Marble Tile or Marble Tile Removal armina Tile Forum/Advice Board 14 09-09-2016 01:55 PM
Marble stone tile over Cultured marble slab shower walls Tap2112 Tile Forum/Advice Board 10 11-30-2015 08:42 PM
questions about threshold/support for marble - marble transition dnsgrrl Tile Forum/Advice Board 23 12-12-2014 01:35 PM
prepping shower for marble installation + finishing marble edges rusty Tile Forum/Advice Board 2 07-02-2008 07:53 AM
Marble tile Backsplash – Formica removed – Tile Spacer ? Ron15617 Tile Forum/Advice Board 1 02-10-2006 12:44 PM
