Unread 09-09-2019, 05:27 PM   #1
gmanderla
Quarry tile set in sand
Asked if I could re-grout quarry tile in a cheese factory. Has anyone ever experienced the tile set in sand. (see pic)
Possible a mud set with cement mixer dissolved?
Greg
gmanderla is offline   Reply With Quote
Unread 09-09-2019, 06:45 PM   #2
That's how the Romans set tile thousands of years ago. It works.
Unread 09-10-2019, 01:54 AM   #3
gmanderla
Would I just re-grout with epoxy?
Would the sand have to be dry?
Should I run from this job?
Greg
Unread 09-10-2019, 05:08 AM   #4
Elkski
Elkski's Avatar
That's an sure has some big black stones in it not very well screened sand it looks like. I would think a cheese factory would be hard use, lots of water washing the floor, chemicals,heavy traffic of carts full of cheese, maybe moving equipment around or installing it. How thick is the sand?
Maybe call these guys ask them for advice after you determine how much sand base is in there. http://aldonchem.com/mt-quarry-tile....RoCoGAQAvD_BwE
Teddy
Unread 09-10-2019, 06:13 AM   #5
Elkski
Elkski's Avatar
Did you take pictures of the cheese did you get a sample
Teddy
Unread 09-10-2019, 07:30 AM   #6
gmanderla
I did get some curds👍🏼 I only went down about 2 inches in sand, not sure what’s below that
Greg
Unread 09-10-2019, 05:36 PM   #7
Can you dig the sand out with your fingers? If you can't, it's not sand, it's likely deck mud (dry pack) mixed too poor. If the sand/mud is fairly solid, thinset the tiles down and grout them. Maybe they set them with pure Portland.
Unread 09-11-2019, 04:54 AM   #8
gmanderla
Yes I can dig sand out with my fingers, about 1/12 inch down and it gets harder. Think I am going to run from this job. Too many variables I don’t know about.
Greg
Unread 09-11-2019, 07:01 AM   #9
Elkski
Elkski's Avatar
i know quarry tiles are supposed to be non permeable but do you think they had some sort of drain system in the sand?
Teddy
Unread 09-11-2019, 06:19 PM   #10
Greg, sounds like running might be a good idea.
Unread 09-12-2019, 10:38 AM   #11
john619
I don't know hardly anything, but I would run away fast.
john
Quarry Tile William Given Cleaning, Restoration and Sealing 2 07-26-2009 03:02 PM
Quarry Tile tiletech78 Professionals' Hangout 45 03-10-2009 07:45 AM
sand set quarry tile or slate? 227ccl Tile Forum/Advice Board 1 10-07-2006 06:57 PM
3/8 IN Quarry tile? Can I still get it? PizzaPrincess Tile Forum/Advice Board 6 08-11-2005 12:53 PM
Quarry tile????? Gabi Cleaning, Restoration and Sealing 3 10-24-2004 08:08 PM
