Unread 09-22-2020, 12:18 PM   #16
redlude97
Now questions for the next steps.
1. I was maybe a bit too aggressive cleaning out the grout between the tiles when laying them to not get my leveling system to messy so I wiped a good bit away at the tops of the entire length of the tiles with my margin trowel. I'm now left with 1/8" wide grout joints that are varying in depth from 3/8"" where the remaining plastic of the leveling clip is to 5/8" where I was too aggressive with my oscillating saw and grout blade. Do I need to fill that entire space with grout or is a bit of air behind the grout going to be an issue for those deeper sections? Should I go back and pre fill with a grout bag or something to bring the level out?
2. The tile had a bit of bowing for the 12x24 along the length and I found I had to back butter and add ridges to the back of the tile in addition to wall with a 1/2" square notch trowel to get 100% coverage and collapse all the ridges. I checked a bunch of the tiles by pulling them up occasionally which was almost impossible to do with the suction but I ended up with some sections with the thinset maybe 1/2" thick behind the tile. Will this fail or cause issues? I used schluter all-set mixed on the heavy side of the consistency according to the instructions for LFT. They don't have a recommendation on max thickness. Everything seems solid and bound well and nothing sounds hollow but I know its supposed to be more like 1/4" thick which is the case towards the edges of the tile but not in the center.
3. Finally, when grouting, the tile is flat with just a microbevel 45. Do I wash until its flush with the tile or down to the microbevel? I'll have a ramp the grout slightly in a couple corners with lippage but want it to look as consistent as possible. I beveled all the edges of my cuts too so there should be a bevel on all grout joints.
Hai
redlude97 is offline   Reply With Quote
Unread 09-25-2020, 12:18 PM   #17
redlude97
Bump. Any help on my questions is much appreciated. Its been hard to piece together the nuances of tiling. Thanks!
Hai
Unread 09-25-2020, 07:08 PM   #18
If I understand the problem, you have some very deep grout joints because you used very thick bonding mortar to flatten your tile installation.
1. Some grouts, usually only the cementitious grouts, can be sensitive to differences in application thickness. This us usually evident where some of the joints are very shallow and others deep. From your description, it appears you have at least 3/8ths of an inch of depth, but some joints are deeper. I would not anticipate the same sort of problem there, but that might also depend upon the ambient conditions when the grout is curing and drying.
You must fill those grout joints, though. If you don't, I think you'll have bigger problems than just a potential for blotchy grout color.
There are non-cementitious grouts that might work well in those uneven joint depths and still yield a uniform color.
2. I've not used Schluter's All-Set and their online information does not indicate that it is a LHT mortar. Does the A118.4 designation on the bag have a letter H after it? Such LHT mortars can be used in sections as thick as 1/2" and some manufacturers specify even thicker allowances. Perhaps someone else out here knows if the All-Set is such a mortar.
3. You would normally be expected to fill those grout joints to the bottom of the micro-bevel on the edges.
Unread 09-26-2020, 12:25 PM   #19
redlude97
Thanks for the reply CX.
1. I was planning on using mapei ultracolor fa which is cement based with a sealer? Will that be an issue? I believe their flexcolor cq is non cement based which I could switch to instead. I will plan on packing the grout joints well. Is simply using a grout float and packing the joint well with multiple passes sufficient or do I need to do something else extra to ensure complete fill?
2. It does not have an H designation but does have a T. I emailed schluter but have not heard back yet. They do have info on their spec sheet for the use of a 3/4" notch for certain applications.
3. Will do that
Thanks again
Hai
Unread 10-05-2020, 11:42 AM   #20
redlude97
So I got around to grouting this weekend using mapei flexcolor CQ, like they warn it sets up fast and it was my first time, so I ended up with grout in some of the change of planes that set up before they could be easily removed. particularly in the niche corners and back edges near the mosaic
So I need to scrape this all out before I caulk the corners with silicone(mapesil T)? I know some people say yes and some say you can caulk over corners.
Is the only concern the change of plane grout cracks or is the space there needed to prevent the tiles from buckling from expansion and popping out?
I could not prevent the grout haze despite washing extensively and changing buckets, probably a dozen 5 gallon buckets total with a rotation of 5 sponges.
In the process I may have over-wet some of the grout joints and overwashed them. They aren't deep but they are more textured from the aggregate compared to other joints which may indicate i washed out some of the surface latex? Will this be an issue long term and should I scrape out and refill these joints or fill over the top? Mapei says the flexcolor sticks to itself unlike cement grouts but will a thin layer fail?
Thanks again in advance
Hai
Unread 10-05-2020, 11:46 AM   #21
Radas
Tile Newbie
I can't remember the name of it now, but Mapei has a specific product they recommend for removal of grout haze on their site/instructions. I've successfully removed haze with that product and a cheesecloth in the past.
You can top off lower grout joints with more flexcolor cq no problem, I've never had an issue with separation or lack of bonding even as shallow as 1/16" although you might find it hard to tool the joint at that depth. Worst case is you wash off the area and start over.
Looks like you handled that sliver cut well too, what method ended up working?
Ali
..a new excuse to hoard tools
Unread 10-05-2020, 11:52 AM   #22
Hai, the only purpose of the flexible sealant in the tile joints at the changes of plane is to provide movement accommodation. If you have grout in those joints, there is no value at all to sealant.
Your choices are to remove the grout and apply the sealant per tile industry standards or just grout the entire joint and take your chances. I have personally grouted many corner joints in new showers and have yet to lose one, but see my warranty information below. It is not uncommon to get hairline cracks when doing that.
I've no long term experience with the MAPEI product, but I have added thin sections to low grout joints with the similar competing Custom product and it works just fine, as advertised.
Unread 10-05-2020, 12:08 PM   #23
redlude97
I ended up dressing my mini wet saw blade and cutting 6 tiles total to finally get something I was happy with. I did drill a hole in the corner then grinded the corner smooth.
For the haze I wish I had just stopped washing as the haze had already set up but kept trying to scrub it off avoiding the grout lines but water still got in them that I had to continue to wipe way. They recommend their epoxy haze remover which I will have to try to pick up next weekend. Does it matter how long it cures for or does the haze remover work better right away?
Hai
Unread 10-05-2020, 12:11 PM   #24
redlude97
My though it that the sealant would hide the grout hairline crack if it were to form. My friend's shower they grouted the corners and they applied clear silicone over the top and that has been holding up for like 10 years.
I'll try to scrape out some of the grout before I apply sealant.
Hai
Unread 10-05-2020, 12:12 PM   #25
Radas
Tile Newbie
I used the haze remover on a 1 year old install over glass tile on some areas I kept putting off cleaning and it worked with some elbow grease. YMMV on a porcelain surface so try scrubbing a scrap tile to make sure it won't alter the glaze before you start.
Good call on the hole at the corner, I'm glad it worked out!
Ali
Unread 01-27-2021, 11:53 AM   #26
redlude97
Hey everyone, just getting back to almost finishing this bathroom, I've put off the silicone until now. I realized I don't know how to address the corners of the niche and window. I installed the schluter trim flat with the inside walls where most people install the schluter in the other direction.
How should I caulk the corners for the cleanest look while providing the proper water barrier?
I'm not sure if I should extend the bead onto the chrome trim all the way out to the outside edge or stop it at the grout line. I can find any good examples of my exact scenario to figure out what would look best
Hai
Unread 01-28-2021, 07:47 AM   #27
Hai, extending the silicone caulk out onto the chrome trim is going to be problematic I think. It isn't going to bond to it especially well, and it is going to be very thin. As such, the likelihood of it peeling off is high.
Confine the caulk to the joints only.
Unread 01-31-2021, 06:34 PM   #28
redlude97
Cleaning thinset from ditra heat mat
A little emergency as I'm panic installing. How do I easily clean the thinset that oozes between the sheets? Sponge and water doesn't work. Help! Thanks y'all
Hai
Unread 01-31-2021, 06:43 PM   #29
I use a sponge and water while the thinset is still wet. You have to keep washing it. It doesn't have to be spotless, just have it clean enough for the wires to pop in place.
Unread 01-31-2021, 07:49 PM   #30
Gozo
And after it hardens, you can break it out with a screwdriver at a shallow angle and a few taps with a hammer. You’d only need to do that if/where the wire goes from one sheet to the next.
Last edited by Gozo; 01-31-2021 at 07:51 PM. Reason: Auto speller was having some fun
Tile over Tile Bathroom Floor-1st Project lorenk2 Tile Forum/Advice Board 4 06-15-2020 08:51 AM
Tile substrate for bathroom stone tile Rymatt Tile Forum/Advice Board 3 12-03-2012 05:04 PM
Bathroom shoe mold - tile walls, vinyl over tile floors HAPPYGRANDPARENT Tile Forum/Advice Board 8 05-01-2011 07:49 PM
Bathroom Tile RW Tile Forum/Advice Board 5 08-06-2009 05:17 PM
bathroom renovation - contractor is laying new tile over old tile - is this right?? txtree Tile Forum/Advice Board 2 11-01-2005 04:36 PM
