Unread 07-15-2012, 12:57 PM   #14026
dhagin
Great lookin work Dave. I can only imagine the work that goes into those re-do's.
Exemplary work as usual, what's that hi-gloss grout Gman?
Originally Posted by Jon
meat slicer
dana
Unread 07-15-2012, 02:32 PM   #14027
Cain
Cain
Spectra lock Dana.
Looks like he just sealed the stones.
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Serving the metro Atlanta area
Cain is offline   Reply With Quote
Unread 07-15-2012, 02:36 PM   #14028
I think maybe it has the sparkle-y additive (Part D?).
Unread 07-15-2012, 05:52 PM   #14029
Katwyk tile
More nice work to look at here Gueuze. I like to see everyone's jobs. There are so many ways today to prep showers and if done correctly they all look the same after grout. However sometimes they may not look the same after 10 years use. I have 28 years in the trade and have mostly worked on custom homes. The guys I started with in Utah never pre floated their shower floors and always wrapped the 2x4 curbs with shower pan material. I would say it was the standard in these parts. I moved to the deseret of Southern California where I learned about hot mopped pans and stucco guys lathing and scratch coating morter on the shower walls. That creates some challenges of it's own. I then moved to the East Bay area of San Francisco, again hot mopped shower floors but there the tile guys would nail up lathe using furing nails and after passing your lathe inspections you would morter float the walls usually in one step no scratch coats. I remember on remodels installing shower pans over a pre float and pouring our curbs solid with wet deck mud pushing the pan material out as close to the front of the curb as possible. We pinched some lathe over the sides of the pan material inside the curb. We never used dam corners and I have worked for 3 large shops that also never used them.
I still mostly do my pans the way I last described. I know of one shower of mine that I did 14 years ago that did fail and we discovered this after 10 years of daily use. The water was going through the outside face of the shower curb and I know if it had dam corners ontop of the curb this would not have happened.
I morter float most of my showers and starting back some 12 years ago I have always floated the entire shower and floor and then candy coated it with a shell of prp 315 and now days with what ever I have in my van with products like Hydroban, Aqua Defence or Red Guard. It helps me sleep at night knowing I have the added water proofing and crack supression. I have seen lots of morter showers with hailine cracks in the tile and I know there will usually always be a crack in the morter behind it.
Katwyk tile is offline   Reply With Quote
Unread 07-15-2012, 06:23 PM   #14030
Katwyk tile
Heres one I am just finishing that has a shower pan liner and standard 3 piece drain. I replaced the top of the drain with an Ebbie square drain. The curb was poured solid with deck mud and then curb and shower floor coated with hydroban. The walls were morter floated and coated with prp315. The wall behind the tub area was morter floated and coated with hydroban. The bench was made out of 2" kerdiboard and after the owner saw the size wanted it bigger. I had to add on to make the top wider and I drilled and glued some 3/8"x3/8" x10" long porcelain sticks I made into the face of the bench to give it some backbone. I also imbedded some fabric mesh in the seat wrapping it all together for some more added strength.
Unread 07-15-2012, 08:24 PM   #14031
dhagin
Great lookin shower Rod.
You made porcelain sticks? What are you, a chemist or sorcerer or somethin? How the hell did ya do that?
dana
Unread 07-15-2012, 08:27 PM   #14032
tilerite
tilerite's Avatar
Awesome pics, everyone. Hope you guys have a great week.
tilerite is offline   Reply With Quote
Unread 07-15-2012, 09:24 PM   #14033
Kilauea
LT
Kilauea's Avatar
Rod,I like your drain approach and seat style.Im starting to play more with the kerdi board,myself.I just made two shampoo niches that I will post later.
Ive got a couple of questions.Im assuming that is HPG,and what looks like H ban afterwards.My question is why both?
Also,what are u using as an adhesive to glue the k board?K fix?I built a seat with some cost efficient urethane shh,seemed to work well.
Speakin of all these (gawd) damn corners!Im actually doin two walkins with Noble cpe.These work the best,but Ive been known to rig up my own in the field.I just cut about a 4'' circle out of the pvc liner,slit halfway thru,and X 15 the shh outta that b.I know some of you're thinking,"what about the pin hole?"-the rubber can actually be stretched and glued over this.The rest of u are like,"circle?slit?."Dont worry,it'll come to you later.
But hey,I got about 6 cpe corners,and about 10 pvc corners.If any of y'all need some.......
*L.T.*
tandctile-dot-net
2nd generation tile installer
Kilauea is offline   Reply With Quote
Unread 07-15-2012, 09:29 PM   #14034
Kilauea
LT
Kilauea's Avatar
Oh,Rod,my bad.Just seen that Loctite tube.I used the same setup.Im always scared thats stuff isnt gonna set up all the way on the inside area (similar to the tube conditions).What are those tubes sticking out from the seat?
Please share w the class.....thanks
*L.T.*
tandctile-dot-net
Unread 07-15-2012, 09:34 PM   #14035
Kilauea
LT
Kilauea's Avatar
Just read the back page-
Davestone,nice fireplace!Very nice detail with the pebbles
Gueuze-tile shower,very beautiful!
bloody finger,very disgusting!
So,where is the after pic with the Laticrete bandaid and one finger salute!!!!!
*L.T.*
tandctile-dot-net
Unread 07-15-2012, 09:42 PM   #14036
dhagin
Those tubes LT are "porcelain sticks". Yea, thats right. Porcelain sticks. And he made em he says.
We need more on those things for sure.
dana
Unread 07-15-2012, 10:30 PM   #14037
Katwyk tile
The porcelain sticks were just some 3/8" wide pieces I cut from the left over floor tile.
LT, That is hpg I used over the k-board to glue in the mesh for more strength. I like your trick on making dam corners.
These pictures are of a steamshower I built out of 3/4" k-board and used mesh tape and thinset over my seams and in my corners. I then coated the entire shower with prp315. I then did my floor Mark Tarkus style with a kerdi drain, bricks for my curb and then painted on 3 coats of aqua-D with mesh fabric on the floor and up the walls 6"or so. The bench is built from cinder blocks with 16" stepping stones on top then the bench was coated with aqua-d
Unread 07-15-2012, 10:37 PM   #14038
Katwyk tile
shower floor detail
Unread 07-16-2012, 03:40 AM   #14039
Davestone
Florida Tile & Stone Man
A lotta nice lookin jobs.
I do like doin artsy stuff for a change,but don't do much like i used to.Of course back then i never took pics thinking i would never run outta work anyway.
http://Davestonestile.com
Unread 07-16-2012, 06:50 AM   #14040
here is a dry stacked stone veneer installation we did in Seffner, FL. on an interior accent wall a week ago.
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
