Unread 03-02-2010, 08:29 PM   #4036
Bill Vincent
Tile Contractor
Bill Vincent's Avatar
Brian-- looking to get about 10 yards of 1 1/2" gravel delivered next week.
Adam's wife drives a little Olds Alero, and it nearly gets lost in the ruts!
Bill
Unread 03-02-2010, 08:41 PM   #4037
Originally Posted by JC
Brian, you ever cut 1/4 or 3/8 off the points on the shelves to allow for the thickness of the wall tile?
I have done some that way.
Unread 03-02-2010, 08:49 PM   #4038
JC
Well actually I was talking about just clipping the point straight off. so the grout joint is smaller where it abuts the wall tile.
JC is offline   Reply With Quote
Unread 03-02-2010, 08:54 PM   #4039
where it returns down I actually back cut the piece of wall tile so it tucks back in there nice.
these I actually cut the shelf square back to the wall.
Unread 03-02-2010, 09:29 PM   #4040
JC
not sure what you mean
See how that last pic you posted returned back to the wall. im talking about the same shape but only a small cut off the end. so the point is the same thickness of the wall tile.
see how it meets up with the tile height?
I know you have probably done it this way just a communication issue
Unread 03-02-2010, 09:37 PM   #4041
yeah I see what you mean. mine comes out the same way.
what I was trying to say is I cut the back of the tile out where the point runs into the wall tile so it makes a small joint, pretty much the same if I were to cut the tip off of the shelf.
Unread 03-02-2010, 10:06 PM   #4042
JC
Oh ok now I see what you mean. yea that makes sense. Different method same result.
Unread 03-02-2010, 10:50 PM   #4043
JC, you can see it back cut better here.
if you dont back cut it or clip the corner yeah you get a huge ugly joint there
where the angle of the shelf drops and touches the back part of the tile.
custom fabricated marble soap corner shelf shelve niche tampa florida tile contractor installer
installation flooring sarasota clearwater seminole largo brandon bradenton lakeland orlando hillsborough pinellas
Unread 03-03-2010, 07:11 AM   #4044
customceramicsllc
licensed tile installation
customceramicsllc's Avatar
thats an A+ corner shelf right there!
John
perfection doesn't start with the tile guy
dead fish go with the flow
customceramicsllc is offline   Reply With Quote
Unread 03-03-2010, 07:15 AM   #4045
HS345
Tile Contractor
HS345's Avatar
I have always been leery of single layer stone tile corner shelves, though I have installed a number of them over the years. How do you all feel about them?
The name's Greg
Unread 03-03-2010, 07:21 AM   #4046
Bill Vincent
Tile Contractor
Not a big fan of em, either. All it takes is one fault unseen in the stone. Just a bit too thin for me.
Bill
Unread 03-03-2010, 08:22 AM   #4047
Yeah, but a good mechanic can figure out how to replace them.
Unread 03-03-2010, 09:44 AM   #4048
Bill Vincent
Tile Contractor
A good mechanic might also rather use something stronger, like 2 cm stone, so they don't HAVE to be replaced.
Bill
Unread 03-03-2010, 11:10 AM   #4049
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
I agree a pc of slab is the way to go. Here is another option. I know a lot of guys do this, I sure didn't invent it.
Cut a pc in tile in half diagonally, flip it so the veins match, akemi it together and shape and polish. A little stronger for those Costco size shampoo bottles.
I also like the notch idea. I started doing that makes it easier to get a nice cut around the shelf. I didn't do that on this picture and you can see the joint is a little big at the corners of the shelf where they hit the wall tile.
This is from the tub surround in my house.
While on the subject of places for shampoo and such, what about niches?Should they 'disappear' into the layout or be a focal point? I always try to get them to land in full tile when possible so that they disappear. I put this one off center so that it is not in the direct stream of the shower head. (But it is waterproofed).
But I have seen some niches look really nice as a focal point too.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 03-03-2010, 04:12 PM   #4050
Around my way you can get shelves in about 6 different colors and they are thicker like 3/4". I prefer them. They retail for 45 bucks.
Shower Progress Pics Electrician Al Tile Forum/Advice Board 15 07-12-2011 11:38 PM
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
