Unread 01-22-2012, 07:17 PM   #1
Hammy
Hammy's Avatar
Bullnose setup
I needed to make some double edge bullnose for the current job.
Been working on this setup after seeing something similar posted here a while back.
I found a used Flex water feed angle grinder.
Bought a 5/16" profile wheel from Braxton-Bragg.
5 small Hold down clamps.
Here are the results:
Took about 10 minutes or less to set up and profile 5 - 12" tiles
Need to do some refinements.
1. use a wider/thicker base
2. use 2 clamps per 12" tile
3. add a 1x under the clamps to take advantage of the adjustments in the clamps.
Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Unread 01-22-2012, 07:32 PM   #2
gueuzeman
Nice setup! A rear stop for the tile to push against (angle aluminum ) could allow you to get away with 1 clamp per piece, also see about corian scraps instead of wood, no warp.
gueuzeman is offline   Reply With Quote
Unread 01-22-2012, 07:37 PM   #3
vrusso123
N. E. Ohio tile-setter
nice Hammy. make sure you let us know of your mods. i just put together a bullnose/ polishing kit and i been thinkin' on that.
vincent
http://russotile.com
"just keep stickin' 'em" - Pat Reagan
vrusso123 is offline   Reply With Quote
Unread 01-22-2012, 08:10 PM   #4
I can't tell what kind of stone you have but of course granite would take longer than marble with the profiling and polishing. Also, a 3/8 radius would probably take a little more time. You have a nice set up though.
Unread 01-22-2012, 08:14 PM   #5
tilejoe
tilejoe's Avatar
Pretty nice. If you have enough bullnose to make, that's the way to go. Be careful about the thickness of each pc. It isn't uncommon for stone to me off a 1/16 or more in thickness...Not a problem for the router (profiler) but the more aggressive pads will dig in where you don't want them to.
I have to say we pretty much free hand everything a pc at a time. Start with the grinder, then work up through the pads depending on what we want the finish to be. Alpha hand pads work quite well if you dont have a ton to do.
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Unread 01-22-2012, 08:22 PM   #6
cwilde72
cwilde72's Avatar
Nice Hammy! Where did you get those clamps from?
Chad Wilde
Precision Tile
Huron, SD
cwilde72 is offline   Reply With Quote
Unread 01-22-2012, 10:21 PM   #7
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
Glad to hear I am not the only one...On Granite counters we try and set up a table and polish a few together so the corners match, but most of the time it is all free hand.
Levi The Tile Guy
Unread 01-22-2012, 10:32 PM   #8
looks like a porcelain tile to me.
Unread 01-23-2012, 06:45 AM   #9
Hammy
Hammy's Avatar
It is porcelain tile. Some hard stuff from LOWES. I BN'ed about 14 ft. Need to BN some for the curb and the the bench seat. And the to make baseboard for the room.
I found the clamps at Harbor Freight. About $3.00 ea. I think.
A rear stop will work if all the pieces are the same width. These were 3".
The proposed mod will use an 8" wide base, the clamps will be fastened to a 1x2 which will be moved in or out based on the tile width. This allow the use of 1 clamp per tile.
Hammy
Unread 01-23-2012, 11:33 PM   #10
dhagin
Nice Hammy. I think Musky Mike has one somethin like that...
dana
Unread 01-23-2012, 11:37 PM   #11
Obie1
Tile Contractor
Obie1's Avatar
I usually use a 6' level, a 1X4, and a couple bags of thinset/grout to hold them down. not as elaborate as Hammys setup, but it gets the job done.
-Obie
ELITE TILE WORKS
(805)845-8787
Southern California ceramic and stone tile contractor serving Santa Barbara and Ventura counties
http://www.elitetileworks.net/
Obie1 is offline   Reply With Quote
Unread 01-24-2012, 06:53 AM   #12
Hammy
Hammy's Avatar
dana
I copied the idea from one I had seen on here some where.
Hammy
conventional bullnose vs. surface bullnose trims Slacker Tile Forum/Advice Board 3 03-06-2011 07:06 PM
Setup Matt@Bayfront Tile Professionals' Hangout 19 02-01-2007 09:44 PM
Newbie thinset setup? lombard Tile Forum/Advice Board 14 11-29-2006 07:30 PM
TM-75 Setup Suggestions? Bob NH Tile Forum/Advice Board 2 11-19-2005 10:23 PM
