Originally Posted by BigCraig
One more thing if I can, when I apply thinset to the concrete, do I run the trowel all the way down to the hardened surface leaving 1/4" trowelded thinset?
Yes, the trowel's bottom teeth will just graze the surface of the floor as you work the thinset around.
But with the repairs that you are doing, you may find it less sloppy to trowel on the thinset to the back-side of each tile. And burn-in (spread a pretty thin layer of thinset using the flat side of the trowel) a coat of thinset on the floor.
