Unread 06-13-2010, 04:21 PM   #1
DavesHammer
How to clean grout sealer from ceramic floor tile?
I applied TileLab grout sealer to our new kitchen floor tile. The tile now has a film along the grout lines. What should I use to remove the grout film from the ceramic tile? I tried water and also a mild soap. No luck.
DavesHammer is offline   Reply With Quote
Unread 06-14-2010, 09:13 AM   #2
Stone Dude
I would try mineral spirits. let it sit on the surface for 30 seconds or so, then scrub with a terry cloth towel.
if that doesnt work you may be able to use a highly diluted solution of sulfamic acid crystals and a terry cloth towel.
doing this will most likely effect the sealer in the grout as well, I would plan on doing one more application. when you put the sealer in the grout, you can immediately buff the excess off the tile with a microfiber rag.
Cameron DeMille
SFA, MIA
MillestoneMarble.com
Unread 06-14-2010, 09:53 PM   #3
doitright
doitright's Avatar
Hi Dave, Welcome!
What is the exact name of the Tile Lab product you used?
If it's a sealer and finish, you're dealing with a topical product. If this is the case, Tile Lab has a high alkaline cleaner called Tile Lab Heavy Duty Cleaner & Stripper that will do the trick.
Before you move forward we need to know the name of that product, because your options are all over the board.
John Koessler
Best sealer and grout for CLEAN travertine? GreenFlute Cleaning, Restoration and Sealing 7 05-23-2010 10:36 PM
Grout Sealer Left a Haze - How to Clean This Up? 2112 Beans Tile Forum/Advice Board 5 09-08-2007 11:21 PM
HELP: Clean grout off ceramic after grouting xgdfalcon Cleaning, Restoration and Sealing 4 10-22-2006 08:02 AM
grout sealer on ceramic tile bill05 Cleaning, Restoration and Sealing 3 01-12-2006 08:41 PM
StoneTech Grout Sealer For Ceramic Tile ewstan Tile Forum/Advice Board 3 02-14-2005 04:11 AM
