Unread 03-29-2009, 08:12 AM   #1
muskymike3
next bath remodel need some advice
First let me say I'm glad I found this forum it sure helped me a lot with a total bath remodel in my house. I moved a wall, relocated lighting, rebuilt a wall installed a niche in the shower which I made of cement board tiled the floor and shower area including the ceiling. I hope to make the next project go faster since it's pretty straight forward.
My next project is the main bath in the house so I want to see if I can keep the toilet and vanity in operation while I replace the tub and tile the tub walls.
questions I have are:
1. Is there any need to install CBU under the tub or can I just install the tub and butt the CBU up to it. The latter would allow me to keep the toilet/sink in operation. The tub is not a drop in.
2. Tiling the tub walls- My tub sits back about 6 inches from an outside corner on one side and I have a door with trim on the other side about 6 inches away also. I'm thinking I should bring the bullnose tile right to the end of the tub or a few inches past. If I go past I'm going to have a funny thin paint line about 3 inches. Bullnose to the outside corner and finish the tiles on the other side up against the trim?
3. Finish outside corners- cbu to sheetrock, what is the preferred method. last remodel I just went over the sheetrock with thinset and made final coats with spackle this allowed me to build up the corner on the sheetrock side and bring the wall right to the edge of the tile.
4. prefab niches- I'm using ceramic tiles how can I finish around the niche and have nice clean edges on tiles with no sharp edges. should I bring bullnose tile from inside the niche to the wall tile and cover that cut edge.
Thank you and sorry for being long winded
muskymike3 is offline   Reply With Quote
Unread 03-29-2009, 09:29 AM   #2
Davestone
Florida Tile & Stone Man
1.No need for cbu under tub.
2.Yes i would die into the trim.
3.Yes same way.
4. I usually put bn on inside of niche unless i want a picture frame look.
http://Davestonestile.com
Unread 03-29-2009, 11:37 AM   #3
muskymike3
Dave, thank you for the reply. I was thinking pretty much the same and appreciate the info from the pros. I did picture frame my other bathroom niche which was all porcelain tile.
any tricks on tiling the floor without having to raise my baseboard heater??
I think I'll have to bite the bullet again on that one. I raised the last one about one inch.
Unread 03-30-2009, 05:54 AM   #4
Hi Mike, Welcome aboard.
Bite the bullet.
Also, one of our moderators goes by Musky Mike. I'm going to ask you to change your username. Normally, this wouldn't be a problem, but in this case it'll cause confusion. Please pick a new one and let me or DaveM know what you choose.
another bath remodel mcmike4817 Tile Forum/Advice Board 5 01-04-2009 12:19 AM
Master Bath Remodel - Poured Concrete on Traditional Foundation - Need Advice!! james.walters Tile Forum/Advice Board 4 11-18-2008 06:28 PM
Bath Remodel CupanTilePaint Professionals' Hangout 1 09-04-2006 07:44 AM
(and another)....Bath Remodel chapperstx Tile Forum/Advice Board 9 01-01-2006 09:28 AM
Remodel bath Ryan M Tile Forum/Advice Board 18 07-25-2003 09:13 AM
