Unread 05-07-2018, 03:42 PM   #1
edeichert
New house, old bathrooms
Hey everyone,
I recently moved to a new house and I'm getting ready to renovate both bathrooms. I had great luck following the advice that I got from the tile forum the last time, so I'm starting a new thread to organize the questions that I'll have moving forward.
Let's start things easy...I need to put down a layer of OSB for my subfloor before putting down Ditra. When fastening the OSB, do I need to use any special screws? I wasn't sure whether something special will be needed, since they'll eventually have thinset over top.
Thanks for your help,
--Evan--
Evan
edeichert is offline   Reply With Quote
Unread 05-07-2018, 04:07 PM   #2
Hi Evan,
The tile cops will probably yell at me, but I've used sheetrock screws for that through the years.
Unread 05-07-2018, 04:12 PM   #3
Welcome back, Evan.
I would first recommend you install plywood rather than OSB as a second layer of subflooring if you plan to bond a membrane to it.
I would recommend you use coated decking screws to do the fastening. Easy to find same at your local building center.
Mastic in bathrooms dpw-ct Tile Forum/Advice Board 3 10-20-2009 08:27 PM
More bathrooms Fractal Tile Forum/Advice Board 23 04-26-2006 10:54 AM
Need help with both bathrooms Cylueth Tile Forum/Advice Board 1 03-12-2006 09:40 PM
bathrooms done! gable74 Tile Forum/Advice Board 6 07-27-2004 04:52 PM
Bathrooms -need some help?? AlexTX Tile Forum/Advice Board 9 09-10-2003 03:35 PM
