Unread 05-30-2010, 02:16 PM   #1
Tmex
Tile Inlay and Hardwood
I am looking for some pointers on installing a tile inlay. What I am looking to do is to have a inlay of tile about 3 x 2 (12 inch tiles) at the front door that will be surrounded by hardwood. Nothing is done yet so I will be starting with a blank canvas.
What someone suggested to me was to create the inlay on a piece of plywood and then glue it into place and then put my hardwood around it. Ultimately the tile will be the same height as the hardwood. Should I put a surround around the tile?
Any tips or suggestions or videos I could view?
Tmex
Toronto, Canada
Tmex is offline   Reply With Quote
Unread 05-30-2010, 02:22 PM   #2
opiethetileman
opiethetileman's Avatar
timex........i would install the wood floor first and let it dry. Then you will know exactly how much float you will have to bring the tile up to be same level.
Are you goona use t cap or try and butt them together... the wood has to move so you will need at least a 1/8 joint filled with either matching silicone to the grout or grout that in...i would do the silicone route myself
opiethetileman is offline   Reply With Quote
Unread 05-30-2010, 02:43 PM   #3
Deckert
I'll second the soft joint versus grout. If you grout it it will likely crack out.
Brannigan
HeenanGC.com
Unread 05-30-2010, 02:44 PM   #4
opiethetileman
or you could always run a schulter trim on the joint
Unread 05-30-2010, 03:21 PM   #5
Tmex
Thanks for the suggestions. Schulter sounds like a good idea but the design maven (wife) will have to vote on that. And thanks for the silicone tip.
Tmex
Toronto, Canada
Unread 05-30-2010, 04:01 PM   #6
Shawn Prentice
Here is an excellent article (Nov 2008 JLC) written by Michael Byrne on just that. It is not free, but it is very informative (maybe someone you know has the issue): http://www.jlconline.com/cgi-bin/jlc.../View/0811inla
Shawn Prentice is offline   Reply With Quote
Unread 05-30-2010, 07:33 PM   #7
Myself, I would tape off the wood and install a matching caulk. Nice finish look in my opinion.
Tile Inlay Marct Tile Forum/Advice Board 6 08-26-2009 01:54 AM
tile inlay on wood canoerat Tile Forum/Advice Board 5 06-01-2009 10:45 PM
Hardwood/Tile Transition - Cutting Hardwood Bengal Tile Forum/Advice Board 5 05-24-2009 08:53 PM
glass tile inlay JoeC Professionals' Hangout 5 06-24-2007 09:57 PM
wood inlay against tile skyshark Tile Forum/Advice Board 2 09-28-2004 07:13 AM
