Hi Todd, Welcome to the forum.
You can use the cardboard shims, I do it. Just make sure they are behind your barrier. If you are using plastic behind your backerboard put up your shims, then plastic, then board. If you are using a sheet or liquid membrane just put your backerboard right over the top of the shims.
Roger (The FloorElf)
Fort Collins, Colorado
