Unread 06-21-2007, 09:50 PM   #1
Hokie01
Shower Pan buildup - offset drain
Hello all - I'm planning out a bathroom remodel and have a somewhat silly question. When I tear out the old shower and start the tile job, I'd like to do myself a favor and not relocate the drain, which is offset from the center of the rectangle.
To do the mud buildup do I just use the 1/4"/ft to the farthest wall and then adjust the slope on the shorter lengths so the final height is level along each of the 3 walls?
Hokie01 is offline   Reply With Quote
Unread 06-21-2007, 09:56 PM   #2
ddmoit
ddmoit's Avatar
You got it right, Hokie. Welcome to the forum. Is there something else we can call you?
How far off center is it? Are you on a slab, or a wooden subfloor? It may not be as hard as you think to center it anyway.
Dan - a DIYer in SE Tennessee
Unread 06-22-2007, 01:19 AM   #3
Hokie01
It's wood subfloor so theoretically it wouldn't be bad...but until I get the old shower out I have no idea what's under there. I'm planning to leave it where it is for now and if I can center it, all the better. Without measuring (because it's late and I'm lazy) I'd say it's a 1/3 vs. 2/3 split on either side of the drain.
This weekend I'm going to try and draw out a plan for the room so I can start a materials list and run the numbers. I think it's time to get a roommate...
Unread 11-15-2007, 06:29 PM   #4
Hokie01
What about Bonsal's pre-formed pans?
So, due to an unexpected delay (shoulder surgery) this project has been put off.
Does anybody have experience with the Bondal pre-formed shower pans? It seems most people here use the Kerdi system but it sounds like the Bonsal product would be a huge timesave. Is the cost an obstacle? Not sure how much they run.
