Unread 04-28-2011, 12:34 PM   #1
sixjs
Idiot proof Floor Leveling before tile
All,
Looking for some help on my kid's bathroom remodel. The floor is up, back down and have 1/4 hardie down too. It's a sixties walkout ranch with the midpoint perpendicular load bearing wall running essentially down the entire lengh of the bathroom. As you could imagine their is somewhat significant sag/sloping away both right and left. (I feel like a drunken sailor walking around in it)
To level I was thinking of building up the edges with leftover strips of hardie screwed and thinseted into place to act as a screed. Put down tar paper, then wire mesh and then SLC using the hardie strips along the edges and the hump from the load bearing wall as my screed. Makes sense? Am I missing anything? Would like to put down 12-13 inch tiles....should I also use ditra after? I don't think I can build the floor up too much more.
thx in advance.
Carl Spackler
sixjs is offline   Reply With Quote
Unread 04-28-2011, 12:56 PM   #2
Carl, if you want to use SLC to flatten your floor, that would work, but not the way you are planning. The SLC must be bonded to the floor, so tarpaper isn't used. It self levels (hence the name) so you don't build screeds, you just keep pouring until you reach the level you want.
There is a comprehensive SLC thread in the liberry you should read.
If you pour enough SLC to meet the manufacturer's minimum thickness, and reinforce it as the manufacturer instructs, you can use it as your tile underlayment and not use Ditra. Nothing wrong with using Ditra if you wanted to use it, just suggesting an alternative.
Unread 04-28-2011, 01:03 PM   #3
sixjs
Thanks BB,
So, I'm looking for the SLC to bond to the hardie then? The old floor (45 year old building practices) had subfloor, tar paper, wire mesh, some type of SLC that appeared to be a really wet portland with the groovy speckled 1 inch tiles laid into.
Home Cheapo had some kind of SLC that talked about a primer like the thread you linked, however I didn't see any of it in stock. Wondering if I could use a comparable primer from the painting section?
thx,
Carl Spackler
Unread 04-28-2011, 01:08 PM   #4
You can pour SLC over Hardibacker. You must prime it first with the recommended primer. Not a paint primer, as the SLC simply won't stick to it.
Your Hardibacker must be installed per James Hardie's instructions, including thinset under the boards, and tape and mud joining the boards. If that is done, then forget about the lath and minimum thickness and the Ditra.
Unread 04-28-2011, 01:49 PM   #5
sixjs
Dang! Looks like I have to pull up the boards and mud 'em back down. At least all the cuts are made.
Carl Spackler
Leveling floor for tile balltrip11 Tile Forum/Advice Board 3 07-05-2010 08:00 PM
tile idiot find 2/12 inch mosaic tiles larryschiff Tile Forum/Advice Board 3 10-04-2008 07:28 PM
Fixing bad tile install ... help the unwitting idiot here tjdabney Tile Forum/Advice Board 18 02-11-2008 09:26 PM
IDIOT layed our tile LynnBeach Cleaning, Restoration and Sealing 3 01-15-2006 04:48 AM
HELP! Tile Idiot and need some help! jlanhlan Tile Forum/Advice Board 21 11-23-2003 06:16 PM
