Unread 03-19-2011, 12:42 PM   #1
Jhoesing
First time tiler
Let me give you the specifics:
117sf kitchen
2x8 joists 16" oc
3/4" subfloor
3/4" T&G floorboards
12x12 tile w 1/4" spacers
I've checked the deflection and I'm good for ceramic tile
I'll be screwing and gluing 3/8 plywood.
Then using versabond to lay in the ditra
Many people say stay away from HD custom blend unmodified
Thinset.... Opinions??
Jeff
Jhoesing is offline   Reply With Quote
Unread 03-19-2011, 02:05 PM   #2
Many people are correct. Go across the street to Lowes and get some Megabond if you want a decent un-modifed thinset to set the tiles on top of the Ditra. Versabond will be OK for setting the Ditra on the plywood subfloor, and will be OK to set tile on top of Ditra, but you will lose Schluter's warranty.
I wouldn't glue the 3/8" plywood. It's not necessary. However, if I did glue it, I'd use a carpenter's glue, like Titebond 2, not construction adhesive. Anything you gun will potentially give you lines of glue and gaps between the lines that are worse than not gluing at all.
First Time Tiler oneslip Tile Forum/Advice Board 17 07-22-2010 06:14 AM
first time tiler Darren.T Tile Forum/Advice Board 22 06-15-2006 11:10 PM
First time tiler, first time poster. reverend_ron Tile Forum/Advice Board 5 01-31-2005 06:25 AM
First Time Tiler. Help!!!! davef23 Tile Forum/Advice Board 1 11-24-2004 08:03 AM
First time tiler DRV Tile Forum/Advice Board 3 09-26-2002 08:19 PM
