Unread 05-24-2009, 10:42 PM   #1
dcatoni
First time tiler, subfloor, and Ditra
I was about to tile my bathroom floor and luckily I found this site. Within a few weeks of buying my 1935 house all the tiles started popping and the grout came out.
Here is what I had to start with from the bottom up:
1.75" X 8.5" joists 16" on center 13' span
3/4" 7" boards perpendicular to joists
1/2" 7" boards parallel to joists
3/16" plywood
thinset and ceramic tile
Here is what I have done so far:
I used the Deflecto and found my floor to be inadequate for the porcelain tile I want to install. So, I spent today sistering one 13' 2X8 to each joist under the bathroom. I used Liquid Nails and 1/2" carriage bolts every foot staggered in an up and down pattern. The existing joists are in very good condition and were nearly perfectly level. I also pulled up all the tile (easily by hand), and some of the plywood.
Here is my plan:
Tear out everything except the bottom 3/4" layer. Screw that layer into the joists with 1 5/8" Deckmate screws. Add a layer of 11/32" plytanium BC screwed to the bottom layer with the deck screws. Then Ditra and tile. The tile is 3/8" thick and the hardwoods outside of the bathroom are exactly 1.5" high from the joists. I want to do this right and have a nice transition.
Basically, my question is, should I go ahead with that plan or do it differently? Also, I just learned about Ditra on this forum so I tried to get more info, but the Schluter website hasn't worked for me all weekend. Does anyone have their technical info in a .PDF?
Dante
dcatoni is offline   Reply With Quote
Unread 05-25-2009, 07:27 AM   #2
Brian in San Diego
Brian in San Diego's Avatar
Dante,
Welcome to the forum! One thing I see wrong with your plan is the thickness of the plywood you want to use. I would use nothing less than 1/2" (15/32") and would prefer 19/32". There are other ways to deal with the transition. You described sistering a joist...did you do only one? I think you'll need to sister the other joists in the bathroom.
The Ditra installation handbook can be found in the Liberry.
Unread 05-25-2009, 07:55 AM   #3
dcatoni
I did every joist under the bathroom. I thought a Liberry was a type of fruit.
Dante
Dante
Unread 05-25-2009, 07:58 AM   #4
Brian in San Diego
Incidentally, when I click on the Schluter Systems link in the Sponsor's column on the right side of the page it opens their website.
Unread 05-25-2009, 09:50 AM   #5
dcatoni
About how thick should the mortar be under and over the the Ditra?
3/4" planks
15/32" plywood
1/8" Ditra
3/8" tile
Gives me a height difference of 7/32" plus mortar. If the mortar is 1/4" wouldn't the transition be to high? If I start from the joists I would be able to use 3/4" ply alone right? It looks difficult to remove the whole subfloor, but I will if I have to.
Dante
Unread 05-28-2009, 07:58 PM   #6
dcatoni
So I think I'm going to put 15/32 ply over my 3/4 planks. Does this floor look good enough? Should I be worried about those planks that are split?
http://s107.photobucket.com/albums/m...t=IMG_2893.jpg
http://s107.photobucket.com/albums/m...t=IMG_2894.jpg
Dante
Unread 05-28-2009, 08:56 PM   #7
Rob Z
Guest
Posts: n/a
Hi Dante,
It's hard to say for sure w/o being there, but after working in a lot of old houses that had 1x subflooring...my opinion is that you should overlay it with the thickest plywood you can stand prior to installing the Ditra. I personally would want to use 3/4" (T&G if I could get it in there and get it to lock together), and no less than 5/8".
We usually separate the 1x from the ply with roofing paper to eliminate squeaks.
Unread 05-30-2009, 06:57 AM   #8
dcatoni
The Schluter website isn't working again. Is it just me or do they shut down their website on weekends?
Dante
Unread 05-30-2009, 07:02 AM   #9
Brian in San Diego
Not working for me either. Some of the information you may be looking for is available on this site and some of the videos are posted on YouTube.
First time tiler help wcd981 Tile Forum/Advice Board 3 02-19-2008 03:08 PM
first time tiler Darren.T Tile Forum/Advice Board 22 06-15-2006 11:10 PM
First time tiler, first time poster. reverend_ron Tile Forum/Advice Board 5 01-31-2005 06:25 AM
First Time Tiler. Help!!!! davef23 Tile Forum/Advice Board 1 11-24-2004 08:03 AM
First time tiler DRV Tile Forum/Advice Board 3 09-26-2002 08:19 PM
