Unread 07-04-2021, 09:51 PM   #1
davems
Mesh imprint from mosaic backing
Hello,
I'm installing some cerrara marble tiles and some of the mosaics have an imprint of the mesh backing from being stacked on one another. I've tried using some dish soap and water with a sponge to remove it but no luck.
Any suggestions on how to remove this?
Thank you!
davems is offline   Reply With Quote
Unread 07-05-2021, 07:34 AM   #2
Hi Dave,
You might try scrubbing with a neutral tile cleaner -- nothing with acid in it.
Unread 07-05-2021, 08:03 AM   #3
jerrymlr1
I would try some soft scrub with a no scratch blue scotch-brite pad on a tile or two. Hopefully the glue didn’t etch the soft marble. Fairly reputable manufacturers place a sheet of paper or plastic between the sheets to prevent this.
Jerry
Mesh Backing for Mosaic, or Paper Front? swilliamsny Tile Forum/Advice Board 13 08-05-2016 11:42 AM
Mesh Tile Backing Help wveil Tile Forum/Advice Board 10 03-09-2015 09:30 PM
Mesh backing problems Obie1 Professionals' Hangout 3 03-26-2011 07:16 PM
Glued Mesh Backing on 1" Travertine Mosaic Sheet kolsen Tile Forum/Advice Board 6 09-18-2009 09:47 PM
mesh backing on mosaic tiles Kurt Shaw Tile Forum/Advice Board 3 05-13-2008 04:47 AM
