Unread 07-01-2021, 01:16 PM   #1
Brown
Pro for Self Leveling, Rochester Hills, Michigan
I am looking for a tile setter that can pour self leveling concrete for my kitchen, laundry, half bath and foyer. Approx. 500 sq. ft. I am in the Rochester hills area of Michigan. The kitchen is on a slab and needs to fill approx. 1/2 inch in the lowest spot. Any recommendations would be appreciated.
Project thread for any discussion.
jack
Brown is offline   Reply With Quote
Unread 07-01-2021, 01:20 PM   #2
Hi Jack,
Curious. Do you need to cover the entire floor or just the low spots?
Unread 07-01-2021, 02:55 PM   #3
Jack, I've put your location in your thread title and moved you to the Professionals' Hangout where you're most likely to be seen by the right people and added a link to your project thread for discussion.
Unread 07-01-2021, 11:06 PM   #4
Brown
self leveling
I guess that the whole floor would want to be covered with it being feather edged if needed at the edges of the floor. Half of the kitchen floor had vinyl flooring glued down and had to be removed by a company that created a lot of low spots in the floor with their large circular grinder. Not to mention the rough finish on the remainder of the floor is the reason that I want it to use self leveling compound. Did I mention that this a slab? I've had a few tile setters look at the floor and most want to use mud to level it out or saying that they can take out any uneven areas with thin set.
The area is 16 x 25 with part of that being a laundry and a half bath. Also a foyer and hall way complete the area. I doubt that they can get a flat and level surface that large with mud. The few tile setters that I've talked to usually admit that they don't use or have had little to no experience with self leveling and prefer to use mud.
I get that.
That's why I'm on this forum to see if anyone in my area has the ability to lay a flat floor with self leveling compound.
The floor needs to be flat and hopefully level.
I've used self leveling compound in my rather small bathroom myself and had no real problems doing it (plywood floor) .Of course I only had to mix two bags but it wasn't a big deal. Sill seal the walls, prime, lath, pour, smooth etc.. .That was over ten years ago and the floor is still in great shape.
It is a large job that's well beyond my capabilities. So, anyone?
(thanks cx)
jack
Unread 07-04-2021, 07:26 AM   #5
I'll bump you up here. I'm not much of a self leveling pro.
Need Contractor for Los Angeles Suburb (Chino Hills) Area mill321 Professionals' Hangout 2 10-23-2018 11:51 PM
Wavey( Hills & Valleys) Bathroom Floor Sam657 Tile Forum/Advice Board 5 05-24-2013 05:43 PM
Need a pro for my new house in Rochester, NY StoneFan Professionals' Hangout 10 11-14-2007 02:01 PM
Anti-Fracture Membrane & Hills/Valleys itsmeid01 Tile Forum/Advice Board 5 07-09-2003 06:32 PM
