Unread 04-17-2019, 11:12 AM   #1
jasondiy112
Tile to drywall corner transition question
Hi,
I'm looking for some advice on making a corner with a wall that is already tiled and drywall that is set not flush with the tile. (See picture for better detail)
I'd use a corner bead but the tile has already been set unfortunately, so I can't put it over the tile. Is this something I just have to fill with joint compound or use a plastic corner liner to hide it (after walls are painted)?
Jason
jasondiy112 is offline   Reply With Quote
Unread 04-17-2019, 11:18 AM   #2
john619
run another schluter trim piece just like the one terminating the tile behind your drywall. there are many profiles available. or you could use J bead trim.
john
john619 is online now   Reply With Quote
Unread 04-17-2019, 11:33 AM   #3
Hi Jason,
Besides the J-metal for drywall there is also an L-metal bead that will cover the drywall edge and just touch the tile. The metal is paintable.
Unread 04-17-2019, 12:06 PM   #4
ZZZK
The big orange store sells a notched vinyl corner bead (but it can be had elsewhere). It looks like this:
https://hw.menardc.com/main/items/me..._CBAVYLMEN.jpg
The notched side can easily be trimmed down to cover your drywall edge and butt up flush against your edge trim. It is then tacked into place using 3M 77 spray glue. Once you do this you can finish your corner with drywall mud (but for this I would use a hot mud). You can then prime and paint and finish it like the rest of the wall. You'll need to caulk the corner at the bottom of your edge trim. This should give you a similar look as if you properly finished the corner prior to tile (what you should have done in the first place) but will be weaker and more prone to cracking than if it was properly finished. It will also make the edge trim look more narrow compared to other places where the edge trim is visible.
John
ZZZK is offline   Reply With Quote
Unread 04-17-2019, 05:37 PM   #5
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
L bead would be easiest and it would give an nice crisp corner.
https://www.homedepot.com/p/1-2-in-x...-202848954-_-N
Peter
Unread 04-18-2019, 12:36 PM   #6
jasondiy112
Thanks for the replies everyone. I'm going to try the L-bead but I'm a little confused because I thought the short side of the L shape was supposed to be pressed against the edge of the drywall but in my case since there is a 1/2 inch gap since the tile wall doesn't come flush with the drywall, will the L-bead still work properly if there isn't any support behind the small portion of the L (aside from it sitting against the tile wallboard).
Jason
Unread 04-18-2019, 01:02 PM   #7
Carbidetooth
Hmmmmm
Not quite sure I get your question but I'll take a stab. You want to bring drywall edge flush with tile? I wouldn't recommend it.
This is how I'd suggest you finish off. Too late in the game for much else.
Peter
Unread 04-18-2019, 01:18 PM   #8
jasondiy112
Yeah that's basically what I was getting at, but I'm guessing if I wanted it flush then I'd have to tear down the drywall and hang new drywall that comes out flush with the tile and then use a J-bead or L-bead on the drywall. Was hoping there was a way to get around that
Jason
Unread 04-18-2019, 01:33 PM   #9
ZZZK
Jason if you use the method I suggested you could actually square the bead the way you want it when you tack it in place and then fill any unevenness with the drywall mud.
John
Unread 04-18-2019, 01:43 PM   #10
speed51133
What about a schluter quadec profile, but the drywall is already up and a profile is already on the tile side??
ugh....
grind off the profile from the tile and then slip a quadec under the drywall???
Unread 04-18-2019, 02:15 PM   #11
Carbidetooth
Hmmmmm
You could hang L bead or corner bead out beyond drywall and fill the blank space behind it with mud. I'd use setting compound.
My concern would be that you're spanning a joint with potentially differential movement and hoping that doesn't telegraph through the assembly in time. Guess you could try and let us know how it fared in a year or two.
In my experience, flushing of almost any surfaces in a structure such as a home is a lesson in frustration. Offsets will typically hide irregularities better.
If I were to look at your installation from the beginning, I"d either hold back tile assembly from corner of wrap around it. Flush kinda demands perfectly plumb, which is frequently not houses.
Peter
Unread 04-18-2019, 02:35 PM   #12
jasondiy112
I'm leaning toward the L-bead for sure, likely will be a game-time decision on which way I go with it -- flush or not. Obviously the easy route and probably correct route at this point is to leave it offset. Just pains me to do that since it won't be a nice clean corner
Thanks for all your ideas!
Jason
Cement Board Drywall Transition Question BarrellOfSkunks Tile Forum/Advice Board 5 05-24-2018 06:55 AM
How to deal with backer board/drywall transition at inside corner ryebotanist Tile Forum/Advice Board 16 10-07-2015 08:53 AM
CBU To Drywall Transition Question Lex Everything Tile Forum/Advice Board 14 06-25-2013 07:51 PM
Transition from Cement board to drywall question taherrmann4 Tile Forum/Advice Board 9 03-06-2011 08:28 AM
CBU to drywall transition question Yaknvdub Tile Forum/Advice Board 9 10-05-2007 06:40 AM
