Unread 09-06-2013, 12:26 AM   #1
jlang
Do I need kerdi with schluter ditra floor?
I am installing schluter ditra as an underlayment for tile in my bathroom. There will be a seam in the middle of the room. Do I need to use the 'kerdi band' to seal the seam? It is the instruction book that comes with the underlayment but not on video. thanks!
Jay
jlang is offline   Reply With Quote
Unread 09-06-2013, 04:27 AM   #2
jondon
jondon's Avatar
Jay, you need to use the band yes if you want the floor area to be waterproof, ditra is waterproof yes but the seams are not. Along the same lines if you want a waterproof floor you would band the wall to floor transition too.
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 09-06-2013, 07:30 AM   #3
jlang
Jay
Unread 09-06-2013, 07:52 AM   #4
Its kind of pointless to waterproof the center of the room and not run the kerdi band up the walls, and attach it to the shower.
We usually waterproof behind the baseboard area.
Someone will come along and whine about the toilet and the doorway, but you can still hold a lot of water on a floor before it hits the doorway.
Unread 09-06-2013, 08:46 AM   #5
Perhaps in Houston, Paul, but here where we make our floors level it can be a bit more of an issue.
Not to mention that in Houston, how would a fella even know if one part of his structure was any wetter than another? I've often wondered how y'all know when you have a plumbing leak.
Unread 09-06-2013, 02:03 PM   #6
For practical purposes, most people do not need to seam the Ditra. ANy water splashed on the floor in a typical bathroom is usually mopped up, and often isn't much anyway, letting things dry out way before it saturates down, finds that seam and gets to the subflooring. It certainly doesn't hurt, but if you have a toilet leak or some other catastrophic water problem, the fact that that is seamed probably won't make much difference. Your choice, your money.
Schluter Ditra/Kerdi Deck Failure Gary MMT Professionals' Hangout 102 11-12-2010 04:37 PM
Need Schluter Ditra and Kerdi Installer in DFW area Linda49 Professionals' Hangout 11 08-02-2010 01:55 PM
Kerdi/Ditra/floor insulation tangodev Tile Forum/Advice Board 1 11-01-2008 01:28 PM
Ditra/kerdi questions; Minimum tile size, Kerdi on ceiling, ditra over wood? Delta_V Tile Forum/Advice Board 9 06-27-2006 07:27 PM
