Unread 01-22-2020, 08:22 AM   #1
adefields
Removing and Replacing A Section of Kerdi Membrane
Hi all-
Not sure if this warrants a new thread, but I couldn't find any info from a search. I am installing the Schluter shower system and I noticed that the Kerdi shower valve cover that I installed has a pretty good size air pocket behind it, and it is wrinkled because I didn't cut the hole for it quite big enough. I'd like to remove it and reinstall a new one, and I suspect this will ruin the kerdi membrane behind it (and part of that membrane isn't sticking to the wall anyway, hence the air pocket).
Any advice on cutting out a section of the Kerdi membrane and replacing it with a new section? I'm looking at maybe a 20 inch by 20 inch section around the shower valve. I would of course, put Kerdi band over the seems. My biggest concern is will the new thinset stick over the old/dried thinset? Do I need to try to scrape most of that off without damaging the wall? Any tips or tricks here?
Adam
Adam
adefields is offline   Reply With Quote
Unread 01-22-2020, 08:39 AM   #2
Welcome, Adam.
Yup, new thinset mortar will stick just fine to old thinset mortar. Scrape off as much of the old as you can, and you don't have to worry about the wall board too much since you're just covering with Kerdi again, but of course don't take any large divots out of it.
Instead of covering the seams with band, just size your new piece so that it will over lap the old by at least 2" on all sides.
Unread 01-22-2020, 07:48 PM   #3
Welcome to the forum, Adam!
Yeah, I’d simply cut a single patch large enough to not need any KerdiBAND. While the KerdiBAND is thinner, you’d otherwise have a double overlap of the KerdiBAND at the corners anyways. So, I’d go with a single patch.
Replacing drywall section, remove trim, or not? CCDIYer Tile Forum/Advice Board 7 12-01-2015 11:38 PM
Replacing a section of caulk? LanceInRaymond Tile Forum/Advice Board 2 07-28-2015 05:33 AM
Laying floor tile/grouting/sealing section-by-section kh36267 Tile Forum/Advice Board 1 02-06-2006 08:27 PM
Removing caulk & replacing OnAMission Tile Forum/Advice Board 20 03-07-2004 03:32 PM
