Unread 01-19-2020, 07:30 PM   #1
Chairandy
Schluter triangular shower seat install
Need help on how to install a Kerdi triangular shower seat (KBSB410TA) on a sloped floor tray and a vertical drain on opposite end of walk in shower. I am using Kerdi board on walls and need advice on how to best install seat on a sloped plane. How do I compensate for the sloped floor? Schluter instructions show the wall area and flloor with troweled thinset before seat installation.Should I make up the front with extra thinset or should something be used to fill the floor gap? Any comments will be greatly appreciated.
Chairandy
Andy
Chairandy is offline   Reply With Quote
Unread 01-19-2020, 07:39 PM   #2
speed51133
You want the bench to have a sloped top, don't forget.
speed51133 is online now   Reply With Quote
Unread 01-19-2020, 07:58 PM   #3
Your bench shouldn't be on the tray. The tray should be cut around it.
If that makes the bench too short, you could build it up with plywood or 2x's.
Unread 01-19-2020, 08:30 PM   #4
Chairandy
Putting triangular bench base on subfloor is the answer. Thanks. That brings me to molded corners ( Schluter products).... anyone know if Schluter corners are available for the configuration of a corner triangular bench?
Andy
Unread 01-19-2020, 08:38 PM   #5
I know once upon a time they had some pre-made 135 degree corners, Andy, but I've not seen mention of them lately. Nor have I done any searching.
I'd recommend you fold your own corners the old fashioned way to ensure that they fit your angles precisely. Put a dab of KerdiFix in the corner of the folds if it makes you feel safer.
Unread 01-19-2020, 09:54 PM   #6
They have some on Amazon.
Make sure you're sitting down before looking at the price. They're quite proud of them.
Unread 01-20-2020, 11:43 PM   #7
Actually I got to wondering, why would you need corners on a Kerdi corner bench against Kerdi board?
Unread 01-20-2020, 11:52 PM   #8
You would if the bench were foam. No foam is waterproof. At the very least you want the seam between the newer kerdi board benches and the kerdi board on the wall.
Unread 01-21-2020, 08:00 AM   #9
D & D Reno
The 135 degree corners come with the bench.
Antonio
D & D Reno is online now   Reply With Quote
Forgot to install corner shower seat - now what rlw1966 Tile Forum/Advice Board 6 10-06-2016 04:15 PM
How to install a shower seat? JC The Mud Box 24 09-05-2011 10:26 AM
how to install a shower seat when using a kerdi presloped pan? Clinton Tile Forum/Advice Board 6 05-14-2008 07:04 AM
Seat install in shower FactorXII Tile Forum/Advice Board 20 07-29-2002 06:31 AM
How to install a corner seat in a tiled stall shower htpups Tile Forum/Advice Board 3 06-03-2002 06:18 PM
