Unread 01-19-2020, 06:10 PM   #1
sgfl81
HardieBacker to Drywall Transition
Just finished installing HardieBacker and I'm not sure the best method to transition to the Drywall. Since the HardieBacker is thinner, the drywall is raised. Any ideas?
Steve
sgfl81 is offline   Reply With Quote
Unread 01-19-2020, 07:40 PM   #2
I would take the Hardi down and rip long 1/8-3/16 shims to nail to the stud. I would also add screws on the sheetrock/paint side to make sure it's tight against the studs. While you're doing that you can check the other studs to make sure the wall is flat and hopefully plumb. I believe the big box stores have drywall shims that can be used for this. I don't know the thickness of the shims.
Although it's not made for this application, I've used thinset to fill low areas in walls and floors. They do make fillers made just for this.
Unread 01-20-2020, 07:17 AM   #3
Welcome, Steve,
Typical DW is 1/2" and "1/2" Hardie is .042, or about 7/16". From here the difference in yours looks to be quite a bit more than 1/16", but maybe the DW isn't fastened to the stud as Davy suggests.
Shims behind the Hardie would work, but if you shim only that one stud the rest of the Hardie might end up not flat; so you might have to shim all the studs that the Hardie is attached to. That, however, really depends on how flat the Hardie is right now.
If your local big box doesn't have DW shims you can order them online. The box I order had 100 shim's, each 1/16" thick, 1.5" wide, and - I think, 45" long.
Unread 01-20-2020, 09:51 AM   #4
Welcome to the forum, Steve.
From the depressed fastener indicator on the Hardibacker, it looks like Steve may have accidentally used 1/4" Hardibacker. Can you measure the thickness of a scrap piece, Steve?
Unread 01-20-2020, 09:56 AM   #5
ave8er
That looks like the 1/4 Hardi
Paul
ave8er is offline   Reply With Quote
Unread 01-20-2020, 10:04 AM   #6
The faces are different? I'd have never guessed.
Unread 01-20-2020, 10:07 AM   #7
smifwal
Is it just one wall that you have to do this to? If you are going to take the time to take down the Hardie why not just buy some durock and put that up instead of all the shimming? And you will be able to assess the studs and make sure everything is plane. You want everything flat prior to putting up you backer board so you are not fixing things on the fly. If you do it with thinset you may have to screed the whole wall otherwise you will have a dip in the middle of the wall.
Unread 01-20-2020, 10:33 AM   #8
Yeah, unless things have changed from the last time I used it....only the 1/4" has the embossed grid, along with the fastener dots. The 1/2" stuff is flat with printed "X"s on it.
Steve, the 1/4" is actually rated by James Hardie to be used for wall tile if your studs are spaced no further than 16" on center...but most pros are too nervous to use it because it's too bendy/flexible. If there's too much flex from someone leaning on the wall, you could possibly crack the tile.
Wedi/Drywall/Hardiebacker transition phillykitty Tile Forum/Advice Board 6 09-22-2014 05:37 PM
Butting Hardiebacker to drywall jlemke Tile Forum/Advice Board 10 02-07-2010 04:53 PM
Son vs Dad. How to bridge a plywood/hardiebacker transition. Grant Garcia Tile Forum/Advice Board 6 03-13-2009 08:52 AM
HardieBacker - Drywall Question Luncon Tile Forum/Advice Board 3 09-19-2007 07:23 AM
Attaching hardiebacker to drywall J Miller Tile Forum/Advice Board 2 06-26-2007 10:26 PM
