Unread 01-24-2020, 11:09 AM   #16
Chowchewey
Not a pro here, but, when I installed glass mosaics I found the stiffness of your float plays a big part in whether you get scratching on the tile. On a test board I tried a rather stiff float with CQ and got very noticable scratching.
When I switched to a softer more forgiving float on a different section CQ did not scratch the glass. I don't know the hardness difference between glass and marble to say if it will work for you but a test would confirm.
Art
Chowchewey is offline   Reply With Quote
Unread 01-24-2020, 01:27 PM   #17
I am asking about cleaning grout that was set long ago.
Unread 01-24-2020, 04:41 PM   #18
rmckee84
rmckee84's Avatar
A PH neutral cleaner would be a good starting point. Something like Stonetech tile and stone cleaner. If that doesn't do the trick you could move onto something a little tougher like a Stonetech klenzall.
Ryan McKee
How does Flexcolor CQ hold up? Jake717 Tile Forum/Advice Board 10 10-08-2019 03:08 PM
Cleaning Flexcolor CQ rgrandy Cleaning, Restoration and Sealing 10 11-08-2018 09:07 PM
Flexcolor CQ amyintx Tile Forum/Advice Board 10 08-22-2015 09:15 AM
