Unread 01-22-2020, 11:10 AM   #1
Plaku76j
Cutting ceramic in place.
Hi there,
First time post, I installed 3x6 subway tile backsplash in my kitchen. On the left side of the window, I measured wrong and need to cut every other tile going up, following the laser level. Should I just take them off and re-install them or can you cut them in place?.
Any recommendations would be appreciated.
Thanks.
Jason
Jason
Plaku76j is offline   Reply With Quote
Unread 01-22-2020, 11:59 AM   #2
Welcome, Jason.
That would be in order to install some "skinnies" up along the window as opposed to just living with what you've got?
Unread 01-22-2020, 12:17 PM   #3
Plaku76j
Yes, I just find it looks off. Mabye I'm just being particular.
Jason
Unread 01-22-2020, 01:26 PM   #4
john619
I understand that the running bond pattern is not being honored along the window the way you have it now. I am kinda particular about those things too and would feel the need to remedy it.
I guarantee that we would be the only ones to really pick up on it and most people would never see it. and in some ways the skinnys may draw your eye more to it............take a black sharpy and draw the alternating verticals then step back and squint your eyes and see if you like the pattern with the skinnys.
If not remove the marker and carry on. or use it as cut line if your inclined to try and cut in place. I think removal would be much better for any cutting.
john
Unread 01-22-2020, 01:48 PM   #5
If you write on that tile with a sharpie you will surely be taking them down and reinstalling a new piece. The sharpie will not wipe off completely.
Unread 01-22-2020, 10:01 PM   #6
Fast eddie part deux
Go to the kids art supplies in the playroom and borrow a washable marker. Or go to walmart and buy one.
Ed
Unread 01-22-2020, 10:13 PM   #7
If those tile are beveled on the end and you cut them in place, they'll probably stand out even more than of you just left them.
What are they bonded with?
Unread 01-22-2020, 11:25 PM   #8
Yeah, what are they bonded with and how long has it been since they were set?
I’m not sure if Kevin or I are more bothered by the pattern not continuing up the left side. Where are you located, I’ll come over to pop ‘em off.
Unread 01-23-2020, 06:18 AM   #9
Plaku76j
Bonded with mastic and it's been 2 days.
The tiles arent the beveled ones, with the really pronounced edge. These ones just have a slight rounded edge. I may just take every other one off and replace them. Any trick to getting them off?.
Thanks guys.
Jason
Unread 01-24-2020, 04:47 PM   #10
rmckee84
rmckee84's Avatar
Grab a small flat bar and pull them off. It will be easier taking the whole row off rather than every other tile.
Ryan McKee
Unread 01-30-2020, 11:08 PM   #11
You might wanna hammer tap a flat putty knife between the tile and drywall as parallel to the substrate as possible.
Cutting installed tile in place BDC Tile Forum/Advice Board 1 06-03-2012 11:18 AM
Cutting tile in place gesres Tile Forum/Advice Board 5 06-12-2007 09:23 AM
Cutting Tile In Place AZ_scottie Tile Forum/Advice Board 5 01-29-2007 04:11 PM
Cutting Granite Tiles In Place Unregistered Tile Forum/Advice Board 7 08-28-2004 08:07 PM
Cutting tile in place Unregistered Tile Forum/Advice Board 1 07-22-2004 06:25 PM
