Unread 01-16-2020, 12:12 PM   #1
tschaeff3
Tile- Cement board transition
I am looking for a product to cover the transition between my tile and the cement board. I am leaning toward a T of some sort but hoping someone with more experience can enlighten me.Name:  IMG_9457.jpg
Tim
tschaeff3 is offline   Reply With Quote
Unread 01-16-2020, 01:26 PM   #2
I would run the tile out further and make a cap using the same tile.
Unread 01-16-2020, 01:44 PM   #3
Welcome, Tim.
I think a photo from a little farther away to give some perspective would help, along with a description of your application.
Unread 01-16-2020, 05:12 PM   #4
tschaeff3
The area of concern is the outside edge of the shower where the shower wall meets the door frame. I am left with an exposed edge on the cement board as well as an exposed edge on the tile. There is a 1 1/4 inch gap between the current tile edge and the edge of the cement board which will be filled with a 1 inch tile cap. I would like to find something to cover both exposed edges while still looking good.
Tim
Unread 01-17-2020, 07:15 AM   #5
Welcome, Tim.
That's going to be a bit of a challenge. What do you plan to do about the door jamb casing (trim) along that side?
Unread 01-17-2020, 08:45 AM   #6
tschaeff3
Good question! I am contemplating using something like the Schlueter reno T transition piece and leaving it at that. My other option is cutting back the exposed cement board to the edge of the existing tile (1 1/4") which would give me 2" to work with.
Tim
Unread 01-17-2020, 08:56 AM   #7
Is the face of the cement board even (in the same plane) as the edge of the door jamb?
Unread 01-17-2020, 10:57 AM   #8
tschaeff3
No, 1/2 inch above.
Tim
Cement board to drywall transition Achilles816 Tile Forum/Advice Board 7 08-09-2019 10:22 AM
Transition from Cement Board to Drywall George001 Tile Forum/Advice Board 6 10-16-2013 11:41 AM
Cement Board / Drywall Transition paulestuart Tile Forum/Advice Board 4 10-08-2009 09:36 PM
Cement Board/Drywall Transition Marko F Tile Forum/Advice Board 5 11-24-2003 06:16 AM
Cement Board transition to drywall Dave S. Tile Forum/Advice Board 26 06-13-2002 06:25 AM
