Old 08-17-2018, 03:45 PM   #1
pecker88
TEC equivalent of ProLite Thinset
0.75 to 1.25 inch thick natural stone veneer, exterior job. Largest piece is prob 10x10 inch. 1/2 inch concrete board got 2 coats of custom building products, redgard.
I called them and they recommended their ProLite modified thinset. The local store here only has white, and the natural stone is dark color. Does that matter? Stone will get grouted dark color.
Is there an equivalent TEK thinset that a local store may have in grey?
Thanks!!
dan
pecker88 is offline   Reply With Quote
Old 08-17-2018, 04:01 PM   #2
rmckee84
rmckee84's Avatar
White is fine, grey thinset may darken your stone even more.
Ryan McKee
Old 08-17-2018, 04:23 PM   #3
pecker88
One more detail. The bottom portion that will also receive Stone will use traditional Type S gray mortar. Do I have to worry about that stone appearing darker than the stone above it that has white thinset?
dan
Old 08-17-2018, 06:15 PM   #4
What is your natural stone?
Help an awesome summer camp finish their cabin after 10 years in the making. They are only $75,000 away.
Old 08-17-2018, 07:37 PM   #5
Will use Type S for what purpose, Dan? Bonding? Grout? Other?
Old 08-17-2018, 10:16 PM   #6
Tiger Mountain Tile Inc
tile lackey
If it's dark stone and dark grout then I would want a gray thinset. Might do a mockup to see how big of a difference gray vs white makes on the stone.
TEC competitor to Prolite would probably be 3n1. However, if cost and availability were no factor, I would buy 3n1 over Prolite any day. And I like Prolite.
Jim Upton
DIYTileGuy
Old 08-18-2018, 06:02 AM   #7
pecker88
@CX: the natural stone supplier included a pallet of Type S mortar when they dropped off the stone. 1/2 of the pallet is not colored, and is the typical grey. The other 1/2 is colored charcoal. Grey is for scratch coat and bonding the stone and the colored is for grout. For the scratch coat, I've been putting a trowel full of masonry cement into each batch, I've read the pre-mixed mortars are usually a little lean.
dan
Old 08-18-2018, 06:03 AM   #8
pecker88
@Tool Guy: Here's a link to the natural stone:
https://www.edwardsstone.com/deep-sea
Deep Sea Ashlar collection.
dan
Old 08-18-2018, 07:35 AM   #9
If you want to change the Type S mortar into a Type M mortar, Dan, you'd really wanna add Portland cement rather than Masonry cement. I've never tried adding Masonry cement to a pre-bagged Type S, though, so I don't know just what you might get.
But I'd still not wanna use that as a bonding mortar for my stone.
Old 08-18-2018, 10:28 AM   #10
Tile & Stone Guild
King Of Tile
Pre-mixed bag goods tend to have too big of sand grit so they can use less cement, sand is cheaper. I find it not sticky enough and easier to break the initial bond.You would be better served getting washed mason sand, type s and some portland and make your own.
Jeff
Old 08-20-2018, 07:41 AM   #11
pecker88
@Tiger Mtn: thanks for the TEC 3N1 recommendation; I found a tile supplier in town that stocks it, but... they only had WHITE! They were able to order grey from another store and will have it tonight for pickup though; will be ready for the mason to start tomorrow. Thanks again.
dan
Old 08-20-2018, 06:23 PM   #12
mark999
Dan,
I am totally confused. You mentioned a lower section and an upper. Then you mention masonary ceement? scratch coat? thinset? The backer oard has 2 coats red guard.Are you using wire lathe? Where? Are you using the ceement straight or adding sand?
Could you please give a detailed description of exactly what miwture you are using and where and how. And how are you using the thinset?
Mark
Old 08-27-2018, 02:13 PM   #13
pecker88
A picture is in order. I'm only talking about the taller pizza oven structure in pic.
8" block make up the base structure. Poured a 5 " thick pad atop the base. Then framed with 16 ga steel studs and skinned with permabase. The block got a scratchcoat of type s premix. The permabase got 2 coats of redgard.
The redgard will get TEC 3n1 thinset, the scratch coat will get colored type s masonry cement for both the stone bond and grout.
dan
Why Not Tile Over Prolite Over Redgard Over Plaster for Tub/Shower Suround? DavidRH Tile Forum/Advice Board 15 01-06-2015 09:17 AM
Laticrete 4XLT vs. CBP Prolite Donnie D. Professionals' Hangout 30 10-13-2013 10:20 AM
Custom Prolite BearBAck Tile Forum/Advice Board 3 10-31-2009 10:48 AM
glass tile and Prolite White problem traceyk Tile Forum/Advice Board 2 05-16-2008 04:21 PM
Install prolite over ditra and kerdi? canuck Tile Forum/Advice Board 25 09-09-2007 01:07 PM
