Unread 07-31-2021, 06:19 PM   #1
senterkitten
Help, will this leak?
I hired a guy how to tile my bathroom I feel like it looks bad and might leak
Sent from my SM-A315G using Tapatalk
senterkitten is offline   Reply With Quote
Unread 07-31-2021, 07:08 PM   #2
In your first picture, what is the middle layer? I guess that picture is taken from the shower floor pointing at the curb.
You could put a test ball in the drain then put a few inches of water in the shower.
Unread 07-31-2021, 08:47 PM   #3
Lou_MA
Is the inside curb tile thinsetted directly to pvc liner?
Lou
Unread 07-31-2021, 11:14 PM   #4
senterkitten
I believe its the liner, concrete board, then the tile.
Unread 07-31-2021, 11:19 PM   #5
senterkitten
Its concrete board. They didn't use any waterproofing to seal it. He told me the boards and grout are waterproof. But that part doesn't have grout. I also can't get the shower head in.
Unread 07-31-2021, 11:46 PM   #6
There's no way to properly use cement board on the inside and top side of the curb. Fastening the cement board requires screws or nails that would penetrate the liner. It's not done to tile industry standards.
Unread 08-01-2021, 12:49 AM   #7
FWIW, cement isn't waterPROOF...it's not damaged by being wetted. The plumbing code calls for NO fasteners through the liner below 2" ABOVE the top of the curb. As said, it's not built to industry standards.
If you did a flood test, yes, it WOULD leak.
Unread 08-01-2021, 08:24 AM   #8
This is what we're seeing more and more these days. Installers that don't understand (or care) how the system works and what guidelines to follow.
Unread 08-01-2021, 01:54 PM   #9
I wouldn't bother leak testing it. It's going to leak.
Looks like purple board on the walls, in addition to the other problems mentioned.
Unread 08-01-2021, 03:58 PM   #10
senterkitten
He's coming back tomorrow to fix some problems. Should I ask him to redo the curb? It wasn't mud or anything just cement board and tile on it. No waterproofing.
Unread 08-01-2021, 05:31 PM   #11
jerrymlr1
Looking at the pictures I would bet there is no waterproofing whatsoever. There should be alkali resistant mesh tape embedded in thinset at all the seams. If there is none at the curb there's a good chance there is none at all. Not only is it going to leak but the grout joints will be cracking within a week.
Looks like the installer is fairly competent at making the work look ok but needs some instruction on procedure. Looks like a start over to me.
Jerry
jerrymlr1 is online now   Reply With Quote
Unread 08-01-2021, 06:15 PM   #12
Some installers only care about what the end result looks like...not necessarily how well it will last or perform. FWIW, a properly built shower should not leak water prior to when the tile is installed...neither the tile nor the grout are considered the waterproofing...they are the decorative, wear surface.
Unread 08-02-2021, 07:05 AM   #13
senterkitten
He keeps telling me the liner keeps the curb waterproof and the pan. Nothing else is needed. I haven't paid him because it looks bad. The marble on top hangs over an inch too.
Unread 08-02-2021, 10:12 AM   #14
Not if you poke holes in it to anchor the cement board! Plumbing code calls for NO penetrations through the liner below 2" ABOVE the top of the curb. The only place you can safely put some is on the outside, preferably down low. On the walls, that also means that the bottom of it is not anchored, at least with screws. Depending on the class of CBU you use, IF it is the one that can be embedded in the setting bed, that is how you anchor the bottom edges...by packing the mud up against it.
Thinset does NOT stick to the liner, so what's holding the marble cap in place? Industry standards also call for at least 95% of the horizontal surface and 100% of the edges to be covered in thinset.
Unread 08-02-2021, 02:22 PM   #15
senterkitten
This is the insideName:  IMG_1141.jpg
Kerdi Shower Leak or Shower Door Leak? cnap Tile Forum/Advice Board 20 07-15-2019 12:54 PM
Leak MineralWater Tile Forum/Advice Board 51 10-12-2015 08:30 PM
Where's the leak? jaydub Tile Forum/Advice Board 4 08-24-2010 06:57 AM
Pan Leak? harbor light Tile Forum/Advice Board 15 02-03-2007 02:33 PM
Do I have a leak? phughes200 Tile Forum/Advice Board 6 05-17-2006 11:19 AM
