Unread 07-31-2021, 06:04 AM   #16
ragtop69gs
ragtop69gs's Avatar
After speaking with both Custom and Mapei tech support folks I've decided that the Mapei Ultra Color FA is the best choice for my grouting. I'll do a test board applying with a grout bag some time this weekend and report back with results.
Jay
Patriot Guard Rider
http://www.patriotguard.org/
'69 Buick GS400
'47 Diamond T 509
"We have been doing so much with so little for so long, pretty soon we will be able to do everything with nothing."
ragtop69gs is offline   Reply With Quote
Unread 07-31-2021, 07:32 AM   #17
As far as timing, each grout / tile combination acts different. Many times, it's obvious the grout will firm up quickly by which tile and grout we're using, other times we know it's going to set slow. I like for the grout to firm up a little in the joint before washing, that usually takes 10-20 minutes but can take longer. Mix and spread some and keep an eye on it. Do not mix the grout runny, I tend to mix it stiffer than a lot of folks. Stiffer grout will help with such wide joints. Mix each batch the same consistency, close to peanut butter but not as runny as pancake batter. A sample board is still a good idea.
Since you plan to wash the grout down low to expose more of the stone, I'd use a rubber grout float instead of a grout bag. A bag will take forever.
Unread 07-31-2021, 09:53 AM   #18
Lou_MA
Pot life and time until first wash are both highly dependent on tile porosity, temps, how stiff the grout is mixed, etc.
I’d err on the side of caution and mix small batches until you get a feel for it. And give the entire bag of dry powder a good mix to thoroughly blend all the ingredients.
Lou
Unread 07-31-2021, 10:43 AM   #19
ragtop69gs
ragtop69gs's Avatar
3:1 mix ratio by volume as per tech support for partial batch size
Jay
Patriot Guard Rider
'69 Buick GS400
'47 Diamond T 509
Unread 08-02-2021, 08:43 AM   #20
ragtop69gs
ragtop69gs's Avatar
I've got all the tile up now and will be sealing it tomorrow. Can I grout the joint where the tile and granite slab meet, I know that changes of plane should be caulked, but in practical application will it be likely to crack if I just grout it? If I must caulk, how should I grout this while still leaving a line for a caulk joint.
Name:  wall to CT.jpg
l
There is also 1 vertical intersecting wall joint .
Jay
Patriot Guard Rider
'69 Buick GS400
'47 Diamond T 509
Unread 08-02-2021, 08:55 AM   #21
If you wanted to caulk that wall/countertop joint, you would have shimmed your stones high enough to accommodate that, Jay. Doesn't look as though that's the case.
Difficult enough to grout what you've got there, 'specially in the manner that Mrs. Jay prefers, and I would be inclined to pay no attention to that joint in your case. Just attempt to grout successfully and call it a day. When it cracks, you're not likely to notice. The crack is likely to allow water to pass through when the top gets wet and you'll need to be perhaps a bit more cautious than otherwise. Not using a flexible sealant at that joint is not correct according to industry standards. I'd smile and say, "Yes, I understand." See my warranty information below.
Unread 08-02-2021, 09:52 AM   #22
ragtop69gs
ragtop69gs's Avatar
That is also what i was thinking, but in spite of how the picture looks, there is a small space between the rock and countertop so there is room for caulk, but with the large voids to fill in spots I wasn't quite sure how to grout then while still leaving space for a caulk joint.
That exterior wall is 2x6 well insulated wall cavities with a 1" foam sheet on the exterior , covered with T-111. There is no noticeable heat or cold transfer from the outside so it does lessen my concern about grouting the plane change. Here in N.W. South Carolina below freezing cold snaps in the winter normally don't last longer than a few hours.
Jay
Patriot Guard Rider
'69 Buick GS400
'47 Diamond T 509
Unread 08-02-2021, 10:23 AM   #23
ragtop69gs
ragtop69gs's Avatar
Jay
Patriot Guard Rider
'69 Buick GS400
'47 Diamond T 509
Unread 08-02-2021, 10:25 AM   #24
Me, too.
Customarily, I'd use strips of cardboard or similar to hold that grout space with irregular "tiles" such as you've got, but I'm not seeing that working well in your case. Well, I see the gapping working, but not the caulking.
Unread 08-02-2021, 06:03 PM   #25
I've used cardboard also but not with pebbles.
What the Wife wants..... Is..... Impalaman1 Tile Forum/Advice Board 89 09-19-2013 03:13 AM
New car, for the wife... Ken The Mud Box 26 06-11-2008 08:55 PM
Tile Saw Abilities Family Man Tile Forum/Advice Board 11 12-18-2007 09:44 PM
Testing, testing sshepherd Tile Forum/Advice Board 2 04-05-2006 08:14 AM
Testing John K Professionals' Hangout 3 04-20-2004 04:18 PM
