Unread 07-09-2021, 04:15 PM   #1
Kevin on Kauai
Shower pan and lowest row of tile replacement
My shower pan has failed. I removed the floor tile, top layer deck mud, liner, and finally the pre-slope mud. Steel nails in the sub-floor had pushed up through the liner, which was a white, paintable elastomeric used in my area as a roofing material. I removed the bottom most row of tile, hardibacker and black roofing paper around the perimeter walls of the shower to get a good look at the studs and blocking, The plywood subfloor looks in decent shape and re-doing the pan properly should be easy after reading various posts on this website.
My question is if there’s an acceptable way to tie into the existing tile, hardibacker, and black paper left on the walls ? As a next resort, I could remove the next row up of tile, leaving the exposed hardibacker to provide overlap for waterproofing going down to the new pan.
Kevin on Kauai is offline   Reply With Quote
Unread 07-09-2021, 05:26 PM   #2
Hi Kevin, welcome. Of course the best thing would be to remove the rest and do the whole thing over. Removing the next row of tiles would allow you to overlap the tar paper but doing so might destroy the hardiboard behind that row as you remove the tiles. Then you would be in the same situation you're in, just another row higher. What kind of shape was the Hardi in behind the bottom row after the tiles were removed? Hardi tends to get brittle as it gets older.
Unread 07-11-2021, 02:03 PM   #3
Kevin on Kauai
Thanks for the reply.
What I found when I removed the lowest row of tile and hardi is good news bad news. Thw good news is removing the next row of tile should be easy because each tile was attached to the hardi by a daps of thin set. The bad news is it looks like the contractor notch trowelled on a layer of thin set on the hardi on all the walls, and let that dry . Then blotched on the blobs of thinset (not sure of the technical term used by the trade when a tiler throws thinset blobs on a wall to set tile). See the pics - left is the back of a tile with blothes of thinset, right is the surface of the hardi with trowelled on layer and blotches of thinset to attach tile.
I'm leaning towards a total removal of tile and hardi.
Unread 07-11-2021, 02:18 PM   #4
Welcome, Kevin.
Lean harder.
Unread 07-11-2021, 03:40 PM   #5
When tiling a shower, even though the walls cover more sq ft, the floor and curb is about half the work. Years ago we use to replace "shower bottoms" but it's really just a band-aid.
Another problem we run into is matching the old tiles. Unless you have more tiles, it's going to look like a patch job.
Unread 07-11-2021, 08:51 PM   #6
Aloha, Kevin.
Yeah, I agree. We don’t want you to think we’re just trying to give you the easy answer of ‘tear it all out’...it’s just that this type of repair is such a band aid and the amount of work trying to tie the new into the old is such that it almost always makes more sense to remove the rest of it and start again.
Was to your fine island back in the ‘90s and I’ll never forget how beautiful it is. Well, except for that knucklehead in the parking lot that I somehow offended from inside my rental car. Never figured that one out.
Unread 07-11-2021, 09:38 PM   #7
You're a Haole, Goldstein. Don't take anything more than that to offend some of the locals.
I usta fly by Kevin's place periodically on my way from O'ahu to French Frigate Shoals, but that was a long, long time ago.
Shower tile replacement jdmckay Tile Forum/Advice Board 43 11-02-2018 08:20 PM
diy, tile-able shower bench in a tub replacement Plank Pitch Shower Base treesecup818@yahoo.com Tile Forum/Advice Board 8 03-30-2013 08:48 AM
Sharp bottom edge on lowest course of tile Chip Forelli Tile Forum/Advice Board 6 09-23-2008 12:35 PM
Tile Shower Pan Replacement NavyWings Tile Forum/Advice Board 32 06-17-2008 06:09 AM
shower pan at lowest level approx 1/4 corner weneedhelp Tile Forum/Advice Board 4 06-24-2007 10:32 PM
