Unread 11-23-2015, 05:39 PM   #1
Lump
Lump's Avatar
Exterior project failing.
I have an exterior project we did earlier this year and now its failing.
This area has only one side open to the elements with roof. (entrance into truck dealership) Will post pictures of project.
Three sides are butting to nothing the forth side butts to door threshold.
Here is the sandwich of materials:
Top: 13x13 exterior porcelain installed on diagonal approx. 11'x24' area
Thinset Durabond Fast set. (directional troweled and back burned)
Greenskin
Greenskin primer
Mapei Ultraplan extreme approx. 3/8" deep
NuHeat cables
Mapei Primer T
Concrete slab (previously had 15 year old tile bonded direct to slab which was not failing)
Appears that the project is failing where greenskin meets the greenskin primer or the greenskin is delaminating. (Most of project is hollow or pulling up. Note that this all happened prior to the temperature getting below freezing here.
There is not much of a slope on the slab nor tile work.
No moisture tests were not completed but is not required from Greenskin.
Any thoughts on what we may have missed when installing this project? Unfortunately our name is on it.
Brad L. Lenz
NTCA Proud Member
Unread 11-23-2015, 05:42 PM   #2
Lazarus
Lazarus's Avatar
While Greenskin works really well in interior projects, I would have concern with it outdoors where there are radical temperature changes......
Laz
Unread 11-23-2015, 05:58 PM   #3
dhagin
Well it happens to the best of us, and being here trying to get to the bottom of it says a lot - good onya. Without having used GS or knowing more, this is what caught my eye.
No moisture tests were not completed...
We all know moisture can be the enemy. How long after SLC was the heat fired up?
dana
Unread 11-23-2015, 06:26 PM   #4
Dave Gobis
da Man!
Dave Gobis's Avatar
I believe they have a moisture vapor limit. None of the other manufacturers require it either, but, they almost all have limits.
Unread 11-23-2015, 07:48 PM   #5
I've seen GS delaminate under higher temps, like in the back of my truck with the black spray on liner.
Just thought I'd throw that out there.
Unread 11-24-2015, 08:43 AM   #6
Sprung831
Tile Tool Guy
Sprung831's Avatar
There was also a bad run of Greenskin earlier this year. Somehow a waxy film of some sort found its way between the foil and the fabric and was causing it to delaminate.
Steve Sprung
Technical Manager
Midwest Trade Tool
www.tiletools.com
Sprung831 is offline   Reply With Quote
Unread 11-24-2015, 11:57 AM   #7
dhagin
Curious if the manufacturer is helping you sort this out Brad? We all know how important it is when using these products that we're not alone in these sorts of things.
dana
Unread 11-24-2015, 12:48 PM   #8
T_Hulse
Tile Contractor
T_Hulse's Avatar
In addition to the possibility of delamination, it could be a problem at the primer/underlayment interface from a primer failure, probably because of improper installation.
Several causes I could think of, most of them about trapping water under a low-perm barrier that permanently keeps the primer in an uncured state of mush (so it's actually a bond breaker instead of bond enhancer):
- Membrane installed too soon over self leveling, before it's fully gotten rid of all it's water. Hard enough to walk on and set tile isn't necessarily the same as dry enough for primer. I see that the latest instructions call for a moisture test and require a dry floor. Are you 100% sure that wasn't the case when you installed it?
- Membrane installed too soon before primer is dry, almost the same as above.
- With one side exposed, it could have gotten rained on in the days before it was sealed in with the underlayment.
- It looks like the current instructions require a sealer, not primer over a slightly damp slab. The old 15-year tile could have withstood a damp slab just fine, but perhaps not a modern primer.
- Some primers don't really cure, they just dry, and can possibly re-emulsify if combined long term with trapped moisture, another possible problem with higher ground/slab moisture.
- Also look for a primer installed too thick or not diluted per the instructions. Do you know exactly which product they used as a primer?
Tom Hulse
Visit my web site here
Unread 11-24-2015, 02:19 PM   #9
Lump
Lump's Avatar
The exact primer was the greenskin primer (which is green in color)
Greenskin primer is no longer available.
My guess is that the primer was not suitable for exterior projects.
I'm thinking we overthought the project and put the bond breaker in place with the primer. I may not know 100% until spring time......
Mapei ultraplan extreme was poured the day before. see link below
http://www.mapei.com/public/US/produ...reme_EN_lr.pdf
Brad L. Lenz
NTCA Proud Member
Unread 11-24-2015, 04:12 PM   #10
CSS
CSS's Avatar
Any expansion joints? You said a bay door. That would be exposed to sun and wind. Also did the customer wait 30 days to turn on the in floor heating?
Robo
www.webspawner.com/users/premiumtileguy
CSS is offline   Reply With Quote
Unread 11-26-2015, 07:50 PM   #11
Lump
Lump's Avatar
Here is a picture of the greenskin down. If you look on edges you can see the green greenskin primer.Name:  14485887035031.jpg
Brad L. Lenz
NTCA Proud Member
Unread 11-27-2015, 07:42 PM   #12
Tiger Mountain Tile Inc
That sucks.
Do you think it's a product failure or an installation failure?
James Upton DIYTileGuy.com
Unread 11-28-2015, 05:26 PM   #13
issbob
Primers can have a lot do with it, but also is it rated for outdoors? I just did a deck in tiles but this was a deck over a living space and in a freezing climate so frost/ thaw cycles makes this difficult. I contacted my Schluter rep and there was a long list of steps which I had to do make this work.. The waterproofing membrane was Jiffy seal 140/60 and came with a primer.
Robert
issbob is offline   Reply With Quote
Unread 08-08-2016, 08:37 AM   #14
Lump
Lump's Avatar
Problem is deeper.
We finally tore out this project and found that the problem is at the bottom with the Mapei Ultraplan Extreme. Will post more pictures as I receive them from the installation team. Any help/advice would be great. We are demoing all the leveler, heat cable and tile then starting fresh.
Brad L. Lenz
NTCA Proud Member
Unread 08-08-2016, 08:46 AM   #15
Lump
Lump's Avatar
[attach][attach]Name:  midstate pic 3.jpg
Size:  82.6 KB[/attach][/attach]
Brad L. Lenz
NTCA Proud Member
Exterior Stair Project Free Spirit Tile Forum/Advice Board 15 06-23-2010 11:13 AM
Exterior grout repair project Mr. Nibbles Cleaning, Restoration and Sealing 7 04-23-2010 03:53 PM
Need Help for Exterior Ceramic Project gkae1998 Tile Forum/Advice Board 1 06-17-2007 07:28 PM
Question on Exterior Porch project C&M Masonry Tile Forum/Advice Board 7 11-01-2006 10:14 PM
exterior backerboard for mosaic project greengirl Tile Forum/Advice Board 11 05-28-2003 07:22 PM
